Edge AI
Ask questions and find answers on how to deploy, debug, and optimize AI models on ST microcontrollers, microprocessors, and smart sensors.
[Short Survey] Please give us your feedbacks on ST model Zoo Services
Hi everyone,   In order to help our developers understand how their work is used and what to do in order to improve model zoo, we kindly ask you to look at this survey about ST Model Zoo Services.   Link of the survey: https://docs.google.com/forms/d...
undefined reference to `ai_emotion_model_create_and_init'
Hi, I am trying to create an STM32Cube.AI application using X-Cube-AI. I am following the documentation under Content 6. I trained my own model and configure the .ioc file as shown below. I wanted to get input from the ADC and feed directly into the ...
goldmine by Associate
  • 1938 Views
HardFault error in ai_platform_network_process()
Hello, I have implemented https://wiki.st.com/stm32mcu/wiki/AI:How_to_perform_motion_sensing_on_STM32L4_IoTnode this project. When I run the program I had a hard fault error when function enters  ai_platform_network_process().  I have incremented the...
Resolved! hsdatalog_to_wav.py conversion not working
Hi, I am currently using SensorTile.box Pro with FP-SNS-DATALOG2 FW. After acquisition, I would need to convert the data from the microphone from .dat to .wav and to do this I am using the hsdatalog_to_wav.py example provided. Unfortunately, the resu...
Gerva by Associate II
  • 4789 Views
Resolved! NanoEdgeAIStudio : is it possible to log ultrasounds ? (STWINKT1B)
Hi, I am using NanoEdgeAIStudio to detect anomalies on microphone signal. I am particularly interested in logging ultrasounds (from 20kHz to 100kHz). I used the Datalogger tool (in NanoEdgeAIStudio) to set up the datalogger and generate the neai_data...
Can you generate ai_model_config.h from cubeMX?
The deploy.py script in stm32ai-modelzoo/image_classification/getting_started generates an extra file, ai_model_config.h which is convenient as it contains the class names and other usefull defines.Is there a way to generate this file from cubeMX?Mor...
AEfth by Associate II
  • 3612 Views
Does cube.ai support quantized onnx models?
I used a quantization tool called ppq to quantize my onnx model because the activation values in the middle layer of this model were too large and I needed to quantize it from float32 type to int8 type. By the way, this model was defined and trained ...
Resolved! Unicleo-GUI not Detecting my NUCLEO-IKS01A3 Board
Hi all, I installed Unicleo-GUI on my Windows laptop, and was able to read sensor data from my NUCLEO-IKS01A3 board successfully. The board was automatically identified by the software as being connected to COM4 yesterday. For some reason today the s...
ZoeTakacs by Associate II
  • 2075 Views
Resolved! STM32H747 Person Detect FP-AI-VISION1 Camera Problem
Hello,I'm working on artificial intelligence on STM32H747. I started my work with projects on FP-AI-VISION. First, I solved the display problem caused by NT35510 and tried the project again. When I tried it, I got the look in the first photo. At firs...
FP-AI-ST-COMMUNITY-QUESTION.jpg koksoybedirhan_4-1703060985558.png koksoybedirhan_3-1703060956990.png
