Edge AI
Ask questions and find answers on how to deploy, debug, and optimize AI models on ST microcontrollers, microprocessors, and smart sensors.
[Short Survey] Please give us your feedbacks on ST model Zoo Services
Hi everyone,   In order to help our developers understand how their work is used and what to do in order to improve model zoo, we kindly ask you to look at this survey about ST Model Zoo Services.   Link of the survey: https://docs.google.com/forms/d...
Resolved! Is there examples on how to upload and use 2 different models using CubeAI?
I would like to upload 2 different ML models to the microcontroller and swap between which one I use for classification (within the microcontroller)However, the code seems only to generate the code for one model properly. Is this correct? or should i...
KSOdin2 by Associate III
  • 1366 Views
Why must we call MX_X_CUBE_AI_Process(); constantly in the while loop?
I have been working on taking measurements with the STMH7 microcontroller and using the measurements with ML to make classification predictions. When I generate the code MX_X_CUBE_AI_Process(); is generated and placed at the end of the while loop. If...
  • 1401 Views
Guidelines for ASC from FP-AI-SENSING1
Did you ever prepare a guideline like this one https://wiki.st.com/stm32mcu/wiki/AI:How_to_perform_motion_sensing_on_STM32L4_IoTnode but for ASC instead?I have my own two-classes NN, keras model and the B-L475E-IOT01.After replacing asc and asc_data ...
MSant.11 by Associate III
  • 2000 Views
Wavelet implementation on an ST Micro MCU
There are several threads concerning FFT's on a ST Micro based ARM processor. We're developing CNN based bearing failure detection. Multiple papers have indicated efficacy of wavelet transforms as a CNN input. Are there threads concerning implementat...
RWash.3 by Associate
  • 1203 Views
NanoEdge AI Studio with FP-SNS-DATALOG1 on microphone data
hi I have logged some data using FP-SNS-DATALOG1 and grouped the data into like 500 rows for NanoEdge AI Studio to train on, how do I place the trained lib into the project as the data out in the FP-SNS-DATALOG1 is different from what I trained the l...
YTan.5 by Associate II
  • 1597 Views
