SPC582B60E1 Pinout Description.
Priya1
Associate
Dear STMicroelectronics Support Team,
I hope this message finds you well.
I am currently working on a design that incorporates the SPC582B60E1MH00Y microcontroller, and I need the detailed pinout description or any supporting documentation that outlines the I/O functions.
I have reviewed the datasheet available on your website, but I would greatly appreciate it if you could share any additional resources, such as application notes, user manuals, or development board schematics, that provide more comprehensive pin mapping information.
Thank you very much for your assistance and support. I look forward to your guidance.
1 ACCEPTED SOLUTION
Accepted Solutions
Peter BENSCH
Welcome @Priya1, to the community!
Unfortunately, this information is a little hidden. The data sheet mentions it in section 3: ‘Refer to the SPC582Bx IO_Definition document.’ and also explains below that it can be found in an Excel file attached to that PDF.
The PDF itself can be found under Technical Notes & Articles as TN1263.
Hope that helps?
/Peter
1 REPLY 1
Peter BENSCH
Hope that helps?
/Peter
