2015-03-18 7:55 AM
I am trying to use the ADC driver (ADCD2) for SPC560D30L3 device using Discovery kit (I have replaced SPC560D40 with SPC560D30 MCU). I am trying to implement a state machine using different states of ADC driver. If my understanding is correct, I shall access the states as below,
switch (ADCD2.state){case ADC_UNINIT:break;case ADC_STOP:
break;
case ADC_READY:
break;
case ADC_ACTIVE:
break;
case ADC_COMPLETE:
break;
case ADC_ERROR:
break;
}If above way is correct the statement 'ADCD2.state' itself is not working! Can anybody clarify the issue? What other settings are required?Thanks in advance for your help.Mike. #adc2015-04-28 7:40 AM
Thanks Erwan for your help. I tried implementing the circular mode but it always gets stuck in function 'ADC_Conversion_Callback' and never allows to reach the main endless loop. If I put breatpoint in above function it is found there always.
I also tried using external int EIRQ17 for displaying the updated value but it is considerable time to update the actual value. Can you please guide in both the above cases?Thanks in for your help.Mike.2015-04-29 4:42 AM
