Procedure to receive data from UART with ISR mode in SPC560P50L5?
RatheeshT
Associate II
Hi Technical team,
Hardware Environment : SPC560P50L5
I am using example program 'SPC560Pxx_RLA SERIAL Test Application for Discovery'
I am able to transmit data to console window by using above example (using UART).
I dont know , how to use this example for receiving data through UART.
Can you guide me support to receive data from UART with ISR ?
Can you give me Application note for UART receive ?
How can i use existing API?
1 ACCEPTED SOLUTION
Accepted Solutions
Erwan YVIN
Hello Ratheesh ,
You are using a SPC560P discovery board.
you can plug a chip on your LIN1RX/LIN1TX and keep LIN0RX/LIN0TX for serial print.
(cf Discovery Kit document)
a lot of student projects are using it.
Best Regards
Erwan
1 REPLY 1
Erwan YVIN
Hello Ratheesh ,
Best Regards
Erwan
