2017-03-21 9:07 AM
I'm using the test application 'STM test Application for discovery' and also if i never used it, when i want to compile it i have this 3 errors:
FMPLL-IN has a value (0) out of range: [4000000,64000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery FMPLL-IN ProblemFMPLL-VCO has a value (0) out of range: [256000000,512000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery FMPLL-VCO ProblemXOSC has a value (0) out of range: [4000000,16000000] configuration.xml /SPC560Bxx_RLA STM Test Application for Discovery XOSC ProblemCan someone help me??
Does someone knows where are those variables and which are the correct values??Many thanks.Solved! Go to Solution.
2017-03-22 2:35 AM
Hello Daniele ,
You have chnaged the default settings.
You can use SPC560Bxx Clocktree in the test application to check your clockpoint.
anyway, please refer to the RM for the permitted value. (Cf Clock Chapter)
Best regards
Erwan
2017-03-22 2:35 AM
Hello Daniele ,
Best regards
Erwan
