2018-01-30 4:17 PM
Hello!
I'd like to use CFlash module without using C90LC Standard Software Driver(SSD).
But I don't konw how to configure it.
Could you provide me an example code?
i.e) CFlash initialize, CFlash Erase, CFlash Write, etc...
Thank you.
2018-02-01 2:28 AM
Hello Hank ,
Officially , we useC90LC Standard Software Driver(SSD)
we have just an example for dflash coming from old posts
Best regards
Erwan
________________ Attachments : spc5_dflash.c.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hy4w&d=%2Fa%2F0X0000000b3i%2FBgicYvVwkEA8migGsDEqekerFan.EmEtJojyRPkYKBY&asPdf=falsespc5_dflash.h.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hy4r&d=%2Fa%2F0X0000000b3c%2FU89O0DvE0YbNG3HcmjYSfvh.XaG_3xPOV5RaeQ020n0&asPdf=false2018-02-01 7:43 PM
Hello, Erwan Y
Thank you for your reply.
But i already had the Dflash sample code. My Dflash sample code is the same as what you attached.
I need a CFlash sample code.
If the CFlash module configure is the same as the DFlash sample code,
Should i change SPC5_DFLASH_BASE address to SPC5_CFLASH_BASE address in sample code?
Thanks.
