Automotive MCUs
eirq interrupt
Hi, can anyone share to me the code for push button that using eirq interrupt? I do see on the example and also successfully build with no error. But when i debug and try to my hardware, nothing happened. LED do not blink when i click on push button
Angle by Associate II
  • 1163 Views
1. to make non cache area in the SPC58NH, making memory attribute to Cache-inhibit is right? 2. what is difference between data descriptors and shared descriptors? 3.The SPC58NH does not support write-through attribute for cache? if can how?
1. to make non cache area in the SPC58NH, making memory attribute to Cache-inhibit is right?2. what is difference between data descriptors and shared descriptors?3.The SPC58NH does not support write-through attribute for cache? if can how?
Calculating faster
Hello,​ I'm working with spc560p and I want to calculate my code my code more faster as usual. I Impelement PIT DRIVER too for other use of my mcu. Is there any method to calculating faster?​Thanks for your attention
DNewm.1 by Associate III
  • 1395 Views
Sensor Driver
Hi, can i know which driver use for displacement sensor? and also can i know which one is the example code for the sensor so that i can refer
  • 875 Views
