Automotive MCUs
SPC560B50L1_HEX_CODE
Posted on July 06, 2016 at 08:15We are loading out.elf out file in to the target using UDE program tool and is working.But we trying to load out.hex file in the target using UDE program tool ,the program is not working in the target.
baskar by Associate II
  • 933 Views
SPC560B50L1_STANDBY_WAKEUP
Posted on July 05, 2016 at 12:54We are using port PA6,PC2 and PC3 pins to wake up from standby mode to run mode.Is it possible these port pins are uses to wake up from standby.
  • 1338 Views
SPC560C05L3 in Standby mode
Posted on June 30, 2016 at 13:43Hi everybody,I'm trying to get my SPC560C05L3 into Standby mode, but it's not working. I also tried other modes, and getting the controller into every RUN mode is no problem, but the other modes just don't work. I use...
mitchel by Associate II
  • 4967 Views
Problem With LINFlex when use DFlash
Posted on June 26, 2016 at 07:56Hi Erwan I Have a problem with LINFlex when i write to DFlash. in my program before in main loop i do this  : 1)  init the LINFlex. 2) init DFlash 3) erase DFlash and the Write to the DFlash successfully. 4) main loop...
SPC560D40L1 : How to implement Watchdog Timer
Posted on June 12, 2016 at 21:51Dear All I want to rum a timer in my MCU: SPC560D40L1. I am using SPC 5studio. Please advise, if i can generate the code for any specific duration watchdog timer or what documents i should refer to rum a timer. Awaiti...
harsh2 by Associate II
  • 1432 Views
SPC560D40L1: Timer
Posted on May 23, 2016 at 11:21Dear AllI want to rum a timer in my MCU: SPC560D40L1.I am using SPC 5studio.Please advise, if i can generate the code for any specific duration timer or what documents i should refer to rum a timer.Awaiting for your ki...
  • 1343 Views
Target Board not getting programmed from SPC560D-DIS board
Posted on May 12, 2016 at 13:02HiI am following PLS adpter settings given in User Manual of SPC560D Discovery board to program my target board having SPC560D30L1 mcu, but instead of target board get programmed, the MCU on discovery board is getting ...
  • 3016 Views
SPC560B50L1_ADC_Configure
Posted on May 19, 2016 at 04:51I need to configure for adc analog channel in SPC560B50L1. Could please give the steps of configuration in the spc studio.Analog ADC configuration:1. PinNo: 312.  PinNo: 323.  PinNo: 35
  • 1007 Views
