2025-11-05 5:18 AM - last edited on 2025-11-05 5:40 AM by Andrew Neil
Moved from STM32 forum - this is not an STM32 question.
I am facing an issue with the Auto Dev Kit debugger. My previous license had expired (Hightec), and although I tried renewing it and even registered to get a new license, the debugger still does not work.
Additionally, I notice that the debugger and flash icons appear greyed out.
Could you please assist me in resolving this issue?
2025-11-05 6:00 AM
@ASH2930T wrote:But I'm using the UDE starter kit
A what?
Do you mean this: https://www.pls-mc.com/products/ude-starterkits/ ?
If so, that mentions only Infineon parts - nothing about ST.
How to write your question to maximize your chances to find a solution
2025-11-05 6:07 AM
The board is connected?
The file is compiled?
I do not see why it should not work...
Wrong version of PLS?
Nothing depending from ST as far as I can see.
2025-11-05 6:09 AM
Can you please confirm what needs to be installed and provide a link to it
2025-11-05 6:12 AM
2025-11-05 6:27 AM
According to the video link you provided, there should be software available for download. However, I couldn’t find any corresponding software on the website. I’ve attached two screenshots — one from the STM website showing my search results and another from the YouTube video you shared — for your reference. Could you please confirm where the software can be downloaded from?
2025-11-05 8:33 AM
You need to download the PLS UDE executable from PLS website because SPC5-UDESTK is obsolete.
If your Windows does not recognize the PLS UDE ports when you connect the board to the PC (look at USB ports in your system), then you need to update the FTDI drivers Drivers - FTDI.
PLS UDE is deprecated because for SPC58 we support OpenOCD. For SPC56/57 please keep using UDE from PLS.
Best Regards,
AutoDevKit Team
2025-11-10 7:07 AM
I have solved the issue, autodevkit works with free license and the error at the start confuses you with pro that you think is not installed, but actually its the free complier which is working. So to conclude we can can just ignore the pro compiler error.
