Analog and audio
Forum board changes
APWorkbench
Posted on June 18, 2018 at 09:14Hi,I am trying to download AP workbench but it says file does not exist, please help me where to download this file.Regards,
TDA7265B free samle
Posted on April 08, 2018 at 21:27Hi, I need a free sample of TDA7265B. It is a class-AB two-channel power amplifier. I didn't find in a list of free samples of integrated circuits of its class. There is a TDA7265 chip, it is very similar but not the...
why the ADS model of PD84008-E can't be installed into ADS?
Posted on March 27, 2018 at 06:14Hello      I am trying to design a 2w transmitter with frequency range of 72mhz to 73mhz, I want to use PD84008-E;I've download  it's ADS model, but I am failed to unzip it into ADS(as below picture), because no lib....
L9663-1-IBIS Model Required
Posted on June 23, 2017 at 13:50Hi,IBIS model not available for this  part number . L9663-1Where can i find the IBIS model ?Is there any I/O model i can use for this part number?Thanks and RegardsArunkumar K#l9663-1
STDP 9320 Athena
Posted on March 14, 2018 at 05:39Hello, i am using BRD TV Board (Athena STDP9320 based), I want to know, which IR Glasses is supported by BRD Board.
ESR/LCR Precision Meter design and implementation...
Posted on February 11, 2018 at 18:17Hello guys,I have recently found myself in a situation where I needed an ESR/LCR meter to do some troubleshooting of a PSU for an old TV set. As usual, the first thing that came to my mind was 'why not build one m...
Zaher by Senior II
  • 1322 Views
