Analog and audio
Forum board changes
TDA7450 datasheet
Please provide datasheet for old audio amplifier, commonly used in car radio. It is marked as TDA7450. Screenshot from service manual on Grundig AD182 in attachment. It has unusual connection. May be any other IC can be used instead of this one.
SZhyl.1 by Associate
  • 1347 Views
关于tda7564b功率
你好,我想请问一下tda7564b,支�?多大w数的扬声器,最大与最�?。谢谢
赵赵.1 by Associate
  • 840 Views
Amplifier - TSC2011 - PSPICE Model Question
Saw that ST provides library for all models together, but what about the .olb file for the schematic representation. Does that need to be created for each part on my end, or am I missing something?
JP-FMT by Associate
  • 848 Views
I am trying to sample data from PDM microphones using DFSDM and then output the audio using SAI setup as a master PCM interface. Is there a way to synchronize the data coming from the DFSDM with the SAI setup in Master mode?
I can get the frequencies close but not exact. I currently have a circular DMA buffer that I put the data in as I receive it from the DFSDM which feeds the SAI. I have this working but since they aren't exactly the same frequency there is underrun or...
dhedin by Associate
  • 1036 Views
