Analog and audio
Forum board changes
TS472
Hi!I'm want to use the component TS472. When I use an input signal -30dBu and a gain 40db it's work fine. When I use an input signalwith 0dBu and a gain 0dB it doesn't word. I don't know why. The outputsignal is less then 1Vpp and not the wave from t...
DSchi.1 by Associate
  • 1504 Views
Enable ADC1 in DMA mode on STEVAL-STLKT01
Hi, I am trying to make the ADC1 on the SensorTile Evaluation board work in DMA mode. I have already gotten great help from @berendi​ on the interrupt mode for the ADC. I am still following this tutorial more or less: https://visualgdb.com/tutorials/...
BBecs.1 by Associate II
  • 585 Views
Low Layer DMA DAC does not start
Hello,i try for moths to get a wave file from SD to the DAC. I the ST LL_DAC_ADC_project description stands.############################################# LL_DAC_EnableDMAReq(DAC1, LL_DAC_CHANNEL_1); // enable DMA for Channel1 LL_DAC_Enable(DAC1, LL_D...
GIkar by Associate III
  • 1034 Views
TSV630 Logic High Level Voltage
Hi,I'm doing a design with TSV630. VCC+ is 3.5 V and VCC- is GND and GAIN=1. What is the minimum Voltage for the SHDN pin to switch the device on? I couldn't find a formular in datasheet. In Datasheed there are only mentioned the different minimum SH...
FHopp.1 by Associate III
  • 932 Views
