2025-04-14 5:39 AM - last edited on 2025-04-14 5:55 AM by mƎALLEm
Moved from this thread.
I just start new project nucleo-H755zi, and default config is quite different to HSE bypassed. If hardware pre-set to STLink provided clock, than why StmCubeMX doesn't initiate project in right way?
Have to navigate into system core, change to bypass. Than have to set manually all clock tree, do useless work that has to be fixed by Cube developers.
2025-04-15 6:48 AM
Hello @MasterT
Your change request has been raised to dev team for feasibility check.
Internal ticket number 207785
I 'will keep you posted with updates
THX
Ghofrane
2025-04-14 5:52 AM
This is another question that needs to be treated separately.
2025-04-15 6:48 AM
Hello @MasterT
THX
Ghofrane
