2023-03-18 2:32 AM
I ran "SetupSTM32CubeMX-6.8.0.sh", it was prompt:
Check exe path on linux
FullExe path1 is: /usr/bin/SetupSTM32CubeMX-6.8.0
Exe path is: /usr/bin
Search java from relative path ----
Checking java in /usr/bin/./jre/bin/java
Checking java in /usr/bin/../jre/bin/java
Checking java in /usr/bin/../../jre/bin/java
Checking java in /usr/bin/../../../jre/bin/java
Please install Java JRE 11.0.10 or a more recent versionsince I have installed java, and the address was:
/usr/bin/javahow could I told the Setup*.sh where java is.
2023-05-09 6:37 AM
My open jdk is installed at /usr/bin. Everything in the jre directory was installed by the tool.
I was able to work around this by installing the IDE, which had not problem, and using the MX embedded in it. I'm still interested in knowing how to fix this.
2023-05-09 4:05 PM
Them the "jre" part breaks the check. Try to create a symlink /usr/bin/jre pointing to /usr ?
