2020-12-27 5:46 PM
2020-12-29 8:24 AM
CubeMx is a GUI java application, java application uses your computer screen resolution to determine the best font size.
But if you want to change it, you have two options
1-Using windows scaling under screen settings(but keep in mind windows in general not good in scaling, so older version is even worse. like windows 7)
2-Change font scaling using jave it self as described in the following link
Regards,
Mazen
