2024-04-05 3:24 AM
Hello?
As title, at STM32H750, when will be fix to use termperature sensor/vbat/vref? In version 1.15, all checkboxes were cleared. Due to migration, the lower version couldn't even read it, so I reset it from the beginning.
And then, it seems that the bug where garbage values of live expressions are displayed is still the same. If I don't write a random value to a random variable, an error that is not displayed normally will remain.
Please review.
2024-04-05 3:55 AM
Hello @LSung.1 ,
I suggest that you take a look at this Post.
The issue was raised to the Dev Team.
Thanks.
Mahmoud.
2024-04-05 3:55 AM
Hello @LSung.1 ,
Thanks.
Mahmoud.
2024-04-05 5:04 AM - edited 2024-04-05 8:48 PM
Same as below.
2024-04-05 6:47 AM
Thank you for reply.
In fact, I updated it with the expectation of debugging the improved live expression written in the release notes, but errors were added that did not exist, causing considerable trouble, so I wrote this article.
I know that live expression is a fairly old bug, but is there any update schedule?
S.Y.Lee
