2020-11-23 4:53 AM
When there is a compilation error involving some includes you get kind of a "stack" trace with includes in the form of
In file included from xxxxxx
from xxxxxx
from xxxx
<actual error>
The actual error part is highlighted in red and clicking on it jumps to the line in the file.
But the 'from' parts are not clickable while this output also contains line numbers, so it should be easy enough to also make them 'jumpable' instead of manually having to navigate to them.
Any tips or tricks to make this possible ?
