2020-11-24 12:57 PM
I would like to share my project on github and used the STM32CubeIDE to configure the periphals and generate some code in addition to my own code. I don't know much about licensing, i just want to share my work so that someone else could benefit from it. Is there any legal problem by publishing my code together with the generated code? Do i have to mention any license on github?
My goal is, that somebody could just download the code, import it into STM32CubeIDE and compile and flash it.
2020-11-25 3:59 PM
Read the license as generated in the source files. As long as you follow that, you're good. Here is an example from one of my generated files:
/* USER CODE BEGIN Header */
* @file : main.c
* @brief : Main program body
* @attention
* <h2><center>© Copyright (c) 2020 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
2020-11-25 3:59 PM
* @file : main.c
* @attention
2020-11-26 12:19 PM
Thanks for the answer. I guess i just leave the code as it is. My generated code has the copyright notice you mentioned.
