Integrating hierarchical state machines (C-code) in STM32CubeIDE projects?
Kmax18
Senior II
Does anyone have experience with integrating hierarchical state machines (C-code) with a STM32CubeIDE project?
For example, the QP/C software by Quantum Leaps generates state machine C-code based on a graphical modeling tool. If the state machine diagram changes the C-code is re-generated: https://www.state-machine.com/qpc/index.html
How can this capability be integrated with the STM32CubeIDE?
  • In particular, if the state machine code is updated, how is the project source updated?
  • Also, if the STM32CubeMX files (.ioc) is updated and the project source is re-generated, how can the state machine code be protected? (I assume the IDE's USER CODE section can be used for that...)
Any feedback will be appreciated. Thank you!
1 ACCEPTED SOLUTION
Accepted Solutions
Andrew Neil
Super User
As far as CubeIDE is concerned, it's all just source files - it neither knows nor cares how those files were created.
So it's no different to files that you create manually yourself.
Place the files in a folder away from the CubeMX stuff to be sure that CubeMX won't mess with it.
PS:
for example, see:
https://community.st.com/t5/stm32cubeide-mcus/project-organisation-in-cubeide-how-to-go-about-libraries/m-p/734773/highlight/true#M31820
and:
https://community.st.com/t5/stm32cubeide-mcus/project-organisation-in-cubeide-how-to-go-about-libraries/m-p/734778/highlight/true#M31821
5 REPLIES 5
Andrew Neil
Super User
PS:
for example, see:
and:
Pavel A.
Super User
@Kmax18 IMHO your question basically is: how to integrate Cube-generated code with your own code and/or code generated by other tools.
As @Andrew Neil wrote, there are BKMs for that. Unfortunate glitches in the Cube re-regeneration may happen, so keep your valuable code protected by version control.
Thank you, @Andrew Neil ! Your articles are very helpful.
Thank you @Pavel A., much appreciated. ("BKM" is Best Known Method, right?)
Correct!
