2019-09-05 10:35 PM
Error loading during project generation, access to the network is allowed in the firewall, the folder with repositories is empty, I can’t download any repository through the program. I just installed the development environment. I don’t want to manually put each repository. Not for this, I switched to this program.
2019-09-11 12:17 AM
Are you still experiencing the same issue? Is it the same in every project you create? If so, could you make a step-by-step guide how you reproduce the problem?
