2026-03-17 12:19 AM - edited 2026-03-17 5:47 AM
Is it ok to use different build configuations for different pinout version?
As you may have experienced, sometimes pcb version how the pinout. Sometimes another UART or TIMER is used in another pin etc,...
2026-03-17 1:47 AM
Hello @carleslsregner
Yes, it is OK and often the best solution to use different build configurations for different PCB/pinout versions,
2026-03-17 1:47 AM
2026-03-17 4:33 AM
Yes, as @Saket_Om said, that's fine.
In situations where Build Configurations are not sufficient, you might take a look at this...
