2023-12-10 10:44 PM - edited 2023-12-13 12:12 PM
Netxduo packet pool is using 51K, plenty I would have thought to download a 16K test file.
This problem was initially seen on an F417 board, and then an F429, so moved on to an H723, specifically the NUCLEO-H723ZG.
I filed a bug report at https://github.com/azure-rtos/netxduo/issues/177 but testing this with a Renesas Rx72N envision kit it works flawlessy, hence this seems like an ST problem.
Console output.
After the first attempt to download the free_packets has been corrupted. normally free_packets is 4 packets less than total_packets.
Thus no further downloads happen.
MX_NetXDuo_Init: Start
MX_NetXDuo_Init: NX_APP_PACKET_POOL_SIZE = 51072
MX_NetXDuo_Init: DEFAULT_PAYLOAD_SIZE = 1536
MX_NetXDuo_Init: Started
STM32 IpAddress: 192.168.125.45
download_test
http_web_request: Start httpbin.org
APP:before nx_dns_host_by_name_get total_packets = 32 free_packets = 28 empty_pool_requests = 0 empty_pool_suspensions = 0 invalid_packet_releases = 0
ERROR: httpbin.org nx_dns_host_by_name_get status=[0xa3]
ERROR: download_test: status =[0xa3]
download_test
Client connected to HTTP server: [3.218.223.42]
nx_web_http_client_created
nx_web_http_client_response_header_callback_set
tls_metadata_size mismatch! calculated:10128 actual:18432
nx_web_http_client{_secure]_connect
http client request initialized
nx_web_http_client_request_send
Received header:
Field name: Date (4 bytes)
Value: Mon, 11 Dec 2023 06:20:30 GMT (29 bytes)
Received header:
Field name: Content-Type (12 bytes)
Value: application/octet-stream (24 bytes)
Received header:
Field name: Content-Length (14 bytes)
Value: 16384 (5 bytes)
Received header:
Field name: Connection (10 bytes)
Value: keep-alive (10 bytes)
Received header:
Field name: Server (6 bytes)
Value: gunicorn/19.9.0 (15 bytes)
Received header:
Field name: Access-Control-Allow-Origin (27 bytes)
Value: * (1 bytes)
Received header:
Field name: Access-Control-Allow-Credentials (32 bytes)
Value: true (4 bytes)
DONE: firmware=1 total bytes=0 errors 0
Error with http response body get: get_status=0x1
APP:Error response body get total_packets = 32 free_packets = 9 empty_pool_requests = 1530 empty_pool_suspensions = 5 invalid_packet_releases = 0
APP:before nx_web_http_client_delete total_packets = 32 free_packets = 9 empty_pool_requests = 1530 empty_pool_suspensions = 5 invalid_packet_releases = 0
APP:after nx_web_http_client_delete total_packets = 32 free_packets = 32 empty_pool_requests = 1530 empty_pool_suspensions = 5 invalid_packet_releases = 0
download_test
APP:before nx_dns_host_by_name_get total_packets = 32 free_packets = 32 empty_pool_requests = 1530 empty_pool_suspensions = 5 invalid_packet_releases = 0
download_test
download_test
Attached project files "nx_httpbin.org.7z" and wireshark capture "stm32h7_httpbin_org_NX_PACKET_POOL_SIZE_32_test-16k.7z" with packet pool count set to 32 and attempting to download 16384 bytes.
Changing to 8192 bytes works fine as below, wireshark file "stm32h7_httpbin_org_NX_PACKET_POOL_SIZE_32_test-8k.7z" attached.
download_test
download_test
Client connected to HTTP server: [75.101.131.185]
Received header:
Value: Mon, 11 Dec 2023 06:49:36 GMT (29 bytes)
Received header:
Received header:
Value: 8192 (4 bytes)
Received header:
Received header:
Received header:
Value: * (1 bytes)
Received header:
DONE: firmware=1 total bytes=8192 errors 0
APP:before nx_web_http_client_delete total_packets = 32 free_packets = 28 empty_pool_requests = 0 empty_pool_suspensions = 0 invalid_packet_releases = 0
APP:after nx_web_http_client_delete total_packets = 32 free_packets = 27 empty_pool_requests = 0 empty_pool_suspensions = 0 invalid_packet_releases = 0
download_test
Received header:
Value: Mon, 11 Dec 2023 06:49:50 GMT (29 bytes)
Received header:
Received header:
Received header:
Received header:
Received header:
Value: * (1 bytes)
Received header:
2023-12-12 11:52 PM
typo in file nx_stm32_eth_driver.c function nx_stm32_eth_driver()
default:
/* Invalid driver request. */
/* Return the unhandled command status. */
driver_req_ptr -> nx_ip_driver_status = NX_UNHANDLED_COMMAND;
/* Default to successful return. */
driver_req_ptr -> nx_ip_driver_status = NX_DRIVER_ERROR;
It should surely should have been
default:
break;
2024-01-25 2:21 PM
Is anyone able to verify the issue that netxduo cannot download large payloads when using nx_web_http_client_secure_connect and nx_web_http_client_response_body_get
The symptom is that part way through the download the nx_stm32_driver corrupts the packet_pool. Seems like Microsoft/express_logic wrote the driver based on the copyright.
I have provided a full example for the H723 named nx_httpbin.org.7z
Any help would be appreciated
Thanks
2024-03-20 4:30 PM
Hello Alec
I find your post because I have a similar issue but on another board (b-l4s5i-iot01a) : impossible to download large file (I'm testing with 38kB). Seems on my side IP stack is stuck somewhere....
Did you get some help on this topic ? Have you found related information that may help ?
Thanks
Joel
2024-03-20 5:31 PM
Hi Joel
You are the first to acknowledge there may be a problem.
Just to be sure we have similar issue, I was able to use http (non secure) and download multi MB files but not with https (secure). IIRC if I assigned a huge amount of NetXDuo memory pool size or increased number of packets to 50 then secure would work. In otherwords the memory pool wasn't being exhausted.
Maybe https://community.st.com/t5/stm32-mcus/how-to-implement-a-webserver-in-stm32-using-netxduo-ethernet/ta-p/641982 could be good starting point to experiment with downloading, but the linked project requires an enormousd amount of NetXDuo memory pool size @ 1536 * 100, that's 150KB of valuable RAM.
Alec
2024-03-21 12:12 AM
Thanks for this first feedback Alec!
I cannot test with http easily now so I do https only. I do small get, put and post with no problem (up to 1KB tested ok).
I have a "small" memory pool for the moment, I should try to increase probably to check (already tried to increase stack sizes, play with thread priorities etc)
150KB is huge yes. But now this remind me a question I had several months ago on a totally different configuration, on zephyr, where I needed to increase the heap size of mbedtls a lot, up to 100KB: https://github.com/zephyrproject-rtos/zephyr/discussions/65093 so maybe it s required but I still consider this is a lot of RAM ....
I will check also my netxduo driver, I m using the one from Microsoft, I need to test the one from ST. I will probably also test my application on a different nucleo board with Ethernet instead of wifi, to compare results.
We keep in touch here!
Joel
2024-03-21 12:15 AM
One more point: are you using the threadx and netxduo port from ST or the mainline repositories from eclipse-threadx ? I m using the mainline repositories on my side, version 6.4.0.
2024-03-26 1:09 AM
With the H7 I was initially testing with 6.2.1 from ST, then Microsoft suggested I try 6.3.0, I had to copy mailine netxduo github code over existing files, refer Microsoft: Could you update your source code to 6.3.0
So no I haven't tried 6.4.0
ST has not updated the packs for F4 F7 read the following thread.
Please advise when azrtos packs for F4 F7 and H7 a... - STMicroelectronics Community
response from ST: I can confirm that X-CUBE-AZRTOS-H7 and X-CUBE-AZRTOS-F4 will be updated to support AzureRTOS 6.3.0 but not in the near future
I have no idea what ST's roadmap is.
ST has abandoned LWIP. Azrtos/ThreadX seems to be going down the same path.
threadx.io commits so far are mainly text changes from Azure RTOS to Threadx.
2024-04-08 2:10 PM
Hello Alec
For your information I managed to get it working here with my B-L4S5I-IOT01A board. Downloading a 1MB file from an HTTPS server.
The modifications I made:
- netxduo pool size increased a lot, I haven't tried to optimize for the moment. Current definitions are the following:
#define NETX_PACKET_COUNT 128
#define NETX_PACKET_SIZE 1200 // Set the default value to 1200 since WIFI payload size (ES_WIFI_PAYLOAD_SIZE) is 1200
#define NETX_POOL_SIZE ((NETX_PACKET_SIZE + sizeof(NX_PACKET)) * NETX_PACKET_COUNT)
