FAQ: STM32MP1 How to get initialized a 'generic GPIO' (to control a LED) with a pull-up/pull down ?
How to configure and drive at run time a  "generic" GPIO a standalone GPIO (not connected to peripheral) ?
How to configure an internal pull-up for LED for example.
Background
Two frameworks are available to configure and control a given pin: pinctrl and GPIOLib. They are selected according to pin usage:
·         pinctrl is used mainly when a pin is controlled by an internal peripheral. Pinctrl handles the pin configuration and allows assigning a specific feature to a pin. The Pinctrl overview article provides an overview of the pinctrl framework.
·         GPIOLib is used when a pin (generic GPIO) needs to be controlled dynamically at runtime (GPIO). GPIOLib is used to control a pin by software. The GPIOLib overview article provides an overview of the GPIOLib framework.
Today GPIO dynamic reconfiguration of pinctrl with GPIO Sysfs (/sys/class/gpio/gpioxx) is deprecated, alternative now is GPIOlib
Answer
 For this the user has to add a GPIO property in node of the existing device driver (or create a st,dummy device driver as in example below) to initialize and control the  “generic GPIO” with the GPIOLib bending.
-> https://wiki.st.com/stm32mpu/wiki/GPIO_device_tree_configuration
Ex: with "foo" device driver that initializes a GPIO with internal Pull-up enabled,
in  foo device driver code :
gpiod_get(&pdev->dev, "function", GPIOD_OUT);
Device tree :
foo_device {
function-gpios = <&gpiob 5 GPIO_ACTIVE_HIGH| GPIO_PULL_UP>;
Examples GPIO Lib usage :
https://wiki.st.com/stm32mpu/wiki/How_to_control_a_GPIO_in_userspace
https://wiki.st.com/stm32mpu/wiki/How_to_control_a_GPIO_in_kernel_space
In OpenSTLinux Ecosystem <2.0.0 it is not possible to use as above GPIOLib to get initialized a GPIO with an internal pull-up/pull-down with flags GPIO_PULL_UP or  GPIO_PULL_DOWN).
Instead we use pinctrl bindings and pintcrl with strict mode disabled (strict mode is to forbid the configuration of a pin at 2 different places (to avoid dual allocation).
At probe a dummy driver will initialize the GPIO with the bias (internal pull up/down) and GPIOLib will allow to change the GPIO output state to high or low
Find an example done on DK2 board with GPIOA14
workspace/sources/linux-stm32mp/arch/arm/boot/dts/stm32mp157-pinctrl.dtsi
            soc {
                        pinctrl: pin-controller@50002000 {
                                    keyleds_pins_a: keyleds_pins_a-0 {
                                                pins {
                                                            pinmux = <STM32_PINMUX('A', 14, GPIO)>;
                                                            bias-pull-up;
                                                            drive-push-pull;
                                                            slew-rate = <0>;
workspace/sources/linux-stm32mp/arch/arm/boot/dts/stm32mp157a-dk1.dts
            ledpa4  {
             compatible = "st,dummy";
                        pinctrl-names = "default";
                        pinctrl-0 = <&keyleds_pins_a>;
                        status = "okay";
B Create dumy driver
#include <linux/module.h>
#include <linux/of_device.h>
#include <linux/kernel.h>
#include <linux/delay.h>
#include <linux/gpio/consumer.h>
#include <linux/platform_device.h>
static int gpio_init_probe(struct platform_device *pdev)
   printk(KERN_INFO "GPIO example init\n");
   return(0);
static int gpio_exit_remove(struct platform_device *pdev)
   printk(KERN_INFO "GPIO example exit\n");
   return(0);
/* this structure does the matching with the device tree */
/* if it does not match the compatible field of DT, nothing happens */
static struct of_device_id dummy_match[] = {
    {.compatible = "st,dummy"},
    {/* end node */}
static struct platform_driver dummy_driver = {
    .probe = gpio_init_probe,
    .remove = gpio_exit_remove,
    .driver = {
        .name = "dummy_driver",
                .owner = THIS_MODULE,
                .of_match_table = dummy_match,
module_platform_driver(dummy_driver);
MODULE_AUTHOR("STMicroelectronics");
MODULE_DESCRIPTION("Gpio example with pinctrl config");
MODULE_LICENSE("GPL");
MODULE_ALIAS("platform:dummy_driver");
after boot
COMMAND : more /sys/kernel/debug/pinctrl/soc\:pin-controller@50002000/pin
pin 14 (PA14): input - high - floating
COMMAND : gpioinfo gpiochip0
line  14:      unnamed       unused   input  active-high
activation led via GPIOlib :
COMMAND : gpioset gpiochip0 14=0 the greend led is ON on the board
pin 14 (PA14): output - low - push pull - floating - low speed
         Reg:     : MODE -OD(or ID)  - OTYPE  - PUPD  -  OSPEED
line  14:      unnamed       unused  output  active-high
probe : modprobe dummy_device
pin 14 (PA14): input - high - pull up
pin 14 (PA14): output - low - push pull - pull up - low speed
(To disable strict mode:
workspace/sources/linux-stm32mp/drivers/pinctrl/stm32/pinctrl-stm32.c
static const struct pinmux_ops stm32_pmx_ops = {
            .get_functions_count     = stm32_pmx_get_funcs_cnt,
            .get_function_name       = stm32_pmx_get_func_name,
            .get_function_groups    = stm32_pmx_get_func_groups,
            .set_mux                       = stm32_pmx_set_mux,
            .gpio_set_direction        = stm32_pmx_gpio_set_direction,
/* PATCH GPIOLib */
        .strict                                = false,
/*          .strict                            = true,*/
Version history
Last update:
‎2020-05-28 2:12 AM
