2023-02-17 5:07 AM
Hello
We are implementing WWDG watchdog in our custom board to cortex-M4 core in cubeIDE tool.
We initialise the following registers
-> enable the clock to WWDG
-> In control register enable the Watchdog enable bit and watchdog counter.
-> In configuration register enabled Early wakeup interrupt and timer base , window value.
while updating the watchdog counter before reaching window value, code is working fine.
While not updating watchdog counter , After some time we are getting Early wakeup interrupt read in status register. In this case code has not restarted. May be what is the issue ?
Is this followed sequence ok/Not ?.
Help me in this regards.
regards
srikanth
2023-03-16 6:06 AM
Hi @Srikanth
sorry for late answer.
Maybe the debugger freeze the WWDG in debug state (See DBGMCU_APB1FZ1/2 registers)
Are you sure your code is not restarted?
It could be restarted but crashed ?
Cortex-M4 could be in hold-boot (RCC_MP_GCR.BOOT_MCU=0)
Regards,
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
