2026-05-22 1:28 AM
stm32f7-i2c i2c@5c002000: pinctrl_select_state_full: pinctrl_config_one: err=-19
[ 1.741795] arm-scmi firmware:scmi: SCMI Protocol v2.0 'ST:' Firmware version 0x0 [ 1.748959] DEBUG: SCMI CLOCK PROBE STARTED! sdev name: scmi_dev.2 I/TC: SCMI-CLOCK: Reporting 34 clocks to Linux I/TC: SCMI-FW: ETZPC ID 2 DENIED for Non-Secure world! I/TC: SCMI-MSG: NS Request Clock ID 15 (iwdg1), ETZPC 2, Access=FAIL I/TC: SCMI-CLK: ID 15 has no name/not found I/TC: SCMI-FW: ETZPC ID 7 DENIED for Non-Secure world! I/TC: SCMI-MSG: NS Request Clock ID 16 (rng1_k), ETZPC 7, Access=FAIL I/TC: SCMI-CLK: ID 16 has no name/not found [ 1.793499] scmi-clocks: probe of scmi_dev.2 failed with error -1050650364 [ 2.404687] clk: Disabling unused clocks [ 2.407399] Warning: unable to open an initial console. [ 2.416636] Freeing unused kernel image (initmem) memory: 2048K [ 2.421697] Run /init as init process [ 12.764703] platform 50000000.rcc: deferred probe pending [ 12.768728] platform soc:pinctrl@50002000: deferred probe pending [ 12.774753] platform soc:pinctrl@54004000: deferred probe pending [ 12.780888] platform 48002000.dma-router: deferred probe pending [ 12.786859] platform 48000000.dma-controller: deferred probe pending [ 12.793189] platform 48001000.dma-controller: deferred probe pending [ 12.799575] platform 58000000.dma-controller: deferred probe pending [ 12.805904] platform 40010000.serial: deferred probe pending [ 12.811539] platform 5c004000.rtc: deferred probe pending [ 12.816959] platform 5c002000.i2c: deferred probe pending [ 12.822322] platform 50028000.thermal: deferred probe pending [ 12.828078] platform stm32-cpufreq: deferred probe pending [ 12.833540] platform led: deferred probe pending [ 12.838168] platform 50001000.pwr: deferred probe pending [ 12.843540] amba 58005000.mmc: deferred probe pending E/TC:1 Panic 'Watchdog' at core/drivers/stm32_iwdg.c:218 <stm32_iwdg_it_handler> I/TC: Halting CPU 0
The log messages below are added by myself. RNG1 and IWDG1 can only be configured as secure peripherals in OP-TEE, so I believe these failure logs are not the cause of the boot stall.
2026-05-22 1:31 AM
2026-05-22 7:21 AM
2026-05-22 8:14 PM
pmic: stpmic@33 {
compatible = "st,stpmic1";
reg = <0x33>;
interrupts-extended = <&exti 55 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
status = "okay";
regulators {
compatible = "st,stpmic1-regulators";
buck1-supply = <&vin>;
buck2-supply = <&vin>;
buck3-supply = <&vin>;
buck4-supply = <&vin>;
ldo1-supply = <&v3v3>;
ldo2-supply = <&v3v3>;
ldo3-supply = <&vdd_ddr>;
ldo4-supply = <&vin>;
ldo5-supply = <&v3v3>;
ldo6-supply = <&v3v3>;
vref_ddr-supply = <&vin>;
boost-supply = <&vin>;
pwr_sw1-supply = <&bst_out>;
pwr_sw2-supply = <&bst_out>;
vddcore: buck1 {
regulator-name = "vddcore";
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1350000>;
regulator-always-on;
regulator-initial-mode = <0>;
regulator-over-current-protection;
vdd_ddr: buck2 {
regulator-name = "vdd_ddr";
regulator-min-microvolt = <1350000>;
vdd: buck3 {
regulator-name = "vdd";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
st,mask-reset;
v3v3: buck4 {
regulator-name = "v3v3";
vdda: ldo1 {
regulator-name = "vdda";
regulator-min-microvolt = <2900000>;
regulator-max-microvolt = <2900000>;
interrupts = <IT_CURLIM_LDO1 0>;
v2v8: ldo2 {
regulator-name = "v2v8";
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
interrupts = <IT_CURLIM_LDO2 0>;
vtt_ddr: ldo3 {
regulator-name = "vtt_ddr";
regulator-min-microvolt = <500000>;
regulator-max-microvolt = <750000>;
vdd_usb: ldo4 {
regulator-name = "vdd_usb";
interrupts = <IT_CURLIM_LDO4 0>;
vdd_sd: ldo5 {
regulator-name = "vdd_sd";
interrupts = <IT_CURLIM_LDO5 0>;
regulator-boot-on;
v1v8: ldo6 {
regulator-name = "v1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
interrupts = <IT_CURLIM_LDO6 0>;
vref_ddr: vref-ddr {
regulator-name = "vref_ddr";
bst_out: boost {
regulator-name = "bst_out";
interrupts = <IT_OCP_BOOST 0>;
vbus_otg: pwr-sw1 {
regulator-name = "vbus_otg";
interrupts = <IT_OCP_OTG 0>;
vbus_sw: pwr-sw2 {
regulator-name = "vbus_sw";
interrupts = <IT_OCP_SWOUT 0>;
regulator-active-discharge = <1>;
onkey {
compatible = "st,stpmic1-onkey";
interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 0>;
interrupt-names = "onkey-falling", "onkey-rising";
power-off-time-sec = <10>;
status = "okay";
watchdog {
compatible = "st,stpmic1-wdt";
status = "disabled";
};Do I need to modify the content of the PMIC node in my device tree?
2026-05-23 6:20 AM
I open optee log level = 3, panic info :
D/TC:? 0 tee_ta_init_session_with_context:562 Re-open trusted service a8cfe406-d4f5-4a2e-9f8d-a25dc754c099
[ 2.642924] scmi_protocol scmi_dev.1: Enabled polling mode TX channel - prot_id:16
[ 2.649869] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 2.656291] Freeing initrd memory: 6400K
[ 2.657075] arm-scmi firmware:scmi: SCMI Protocol v2.0 'ST:' Firmware version 0x0
E/TC:1 0 Panic at core/arch/arm/plat-stm32mp1/shared_resources.c:142 <get_gpioz_nbpin>
I/TC: Halting CPU 0
then i change -> (#include "stm32mp15xxad-pinctrl.dtsi" to "stm32mp15xxaa-pinctrl.dtsi"),panic info :
[ 2.838500] stm32-ipcc 4c001000.mailbox: ipcc rev:1.0 enabled, 6 chans, proc 0
[ 2.845549] of_clk_hw_onecell_get: invalid index 21
[ 2.849160] stm32mp157-pinctrl soc:pinctrl@50002000: error -EINVAL: failed to get clk
[ 2.857035] stm32mp157-pinctrl: probe of soc:pinctrl@50002000 failed with error -22
[ 2.866205] stm32mp157-pinctrl soc:pinctrl@54004000: at least one GPIO bank is required
[ 2.872766] stm32mp157-pinctrl: probe of soc:pinctrl@54004000 failed with error -22
[ 2.885411] stm32-rproc 10000000.m4: wdg irq registered
[ 2.889646] remoteproc remoteproc0: m4 is available
[ 2.900537] clk: Disabling unused clockshow to resolve this question?
2026-05-23 8:33 AM
[ 2.872801] Unable to register uart4_k
[ 2.875128] stm32mp1_rcc 50000000.rcc: Can't register clk uart4_k: -17
[ 2.881687] stm32mp1 clock failed to initialize
[ 2.886187] stm32mp1_rcc: probe of 50000000.rcc failed with error -17
D/TC:? 0 scmi_msg_get_clock_handler:604 SCMI-CLK: Msg 0x7 on Chan 0
D/TC:? 0 scmi_msg_get_clock_handler:604 SCMI-CLK: Msg 0x6 on Chan 0
[ 2.929309] stm32_rtc 5c004000.rtc: registered as rtc0
[ 2.933067] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:00:16 UTC (946684816)
[ 2.942184] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[ 2.947879] stm32_rtc 5c004000.rtc: registered rev:1.2
[ 2.993162] clk: Disabling unused clocks
[ 3.003250] 8<--- cut here ---
[ 3.004848] Unable to handle kernel paging request at virtual address e8b76218 when read
[ 3.012939] [e8b76218] *pgd=c3138811, *pte=00000000, *ppte=00000000
[ 3.019209] Internal error: Oops: 7 [#1] SMP ARM
[ 3.023819] Modules linked in:
[ 3.026863] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 6.6.116 #1
[ 3.032862] Hardware name: STM32 (Device Tree Support)
[ 3.037997] PC is at clk_gate_is_enabled+0xc/0x44
[ 3.042695] LR is at clk_core_is_enabled+0x40/0xec
[ 3.047481] pc : [<c09b0bc0>] lr : [<c09a839c>] psr: 60000093
[ 3.053746] sp : e8815ec0 ip : 00000000 fp : 00000000
[ 3.058966] r10: c1c578e4 r9 : c1bcf858 r8 : 00000000
[ 3.064187] r7 : 60000013 r6 : 00000000 r5 : 00000000 r4 : c3164f00
[ 3.070714] r3 : e8b76218 r2 : 00000000 r1 : c3162d40 r0 : c31651c0
[ 3.077240] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 3.084465] Control: 10c5387d Table: c020406a DAC: 00000051
[ 3.090206] Register r0 information: slab kmalloc-128 start c3165180 pointer offset 64 size 128
[ 3.098907] Register r1 information: slab kmalloc-64 start c3162d40 pointer offset 0 size 64
[ 3.107348] Register r2 information: NULL pointer
[ 3.112046] Register r3 information: vmalloc memory
[ 3.116919] Register r4 information: slab kmalloc-192 start c3164f00 pointer offset 0 size 192
[ 3.125535] Register r5 information: NULL pointer
[ 3.130234] Register r6 information: NULL pointer
[ 3.134933] Register r7 information: non-paged memory
[ 3.139981] Register r8 information: NULL pointer
[ 3.144681] Register r9 information: non-slab/vmalloc memory
[ 3.150338] Register r10 information: non-slab/vmalloc memory
[ 3.156082] Register r11 information: NULL pointer
[ 3.160868] Register r12 information: NULL pointer
[ 3.165654] Process swapper/0 (pid: 1, stack limit = 0x084cd6bf)
[ 3.171658] Stack: (0xe8815ec0 to 0xe8816000)
[ 3.176018] 5ec0: c3164f00 00000000 00000000 c1b3e104 c3045e40 c3164f00 c20e0000 00000007
[ 3.184197] 5ee0: 00000000 c1b3e0b8 c3045e40 c1fd25b0 c20e0000 00000007 00000000 c1b3e290
[ 3.192378] 5f00: c1b3e224 c1f73ae0 c20e0000 c030248c c2260941 00000000 c2260958 00000000
[ 3.200556] 5f20: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.208736] 5f40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c861261a
[ 3.216917] 5f60: 00000192 c2260900 c1bcf838 00000007 c191f068 c1b013a0 00000007 00000007
[ 3.225097] 5f80: 00000000 c1b004d0 c1d04d00 c1263724 00000000 00000000 00000000 00000000
[ 3.233277] 5fa0: 00000000 c126373c 00000000 c03001ac 00000000 00000000 00000000 00000000
[ 3.241456] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.249637] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 3.257820] clk_gate_is_enabled from clk_core_is_enabled+0x40/0xec
[ 3.264078] clk_core_is_enabled from clk_disable_unused_subtree+0x74/0x194
[ 3.271039] clk_disable_unused_subtree from clk_disable_unused_subtree+0x28/0x194
[ 3.278607] clk_disable_unused_subtree from clk_disable_unused+0x6c/0x10c
[ 3.285481] clk_disable_unused from do_one_initcall+0x58/0x200
[ 3.291400] do_one_initcall from kernel_init_freeable+0x210/0x26c
[ 3.297578] kernel_init_freeable from kernel_init+0x18/0x130
[ 3.303322] kernel_init from ret_from_fork+0x14/0x28
[ 3.308367] Exception stack(0xe8815fb0 to 0xe8815ff8)
[ 3.313419] 5fa0: 00000000 00000000 00000000 00000000
[ 3.321601] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.329780] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3.336397] Code: eafffff7 e5d02011 e590300c e3120004 (e5931000)
[ 3.342483] ---[ end trace 0000000000000000 ]---
[ 3.347091] note: swapper/0[1] exited with irqs disabled
[ 3.352506] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 3.360065] CPU0: stopping
[ 3.360078] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 6.6.116 #1
[ 3.360092] Hardware name: STM32 (Device Tree Support)
[ 3.360103] unwind_backtrace from show_stack+0x10/0x14
[ 3.360140] show_stack from dump_stack_lvl+0x40/0x4c
[ 3.360170] dump_stack_lvl from do_handle_IPI+0x1b8/0x1ec
[ 3.360201] do_handle_IPI from ipi_handler+0x18/0x20
[ 3.360229] ipi_handler from handle_percpu_devid_irq+0x8c/0x1d8
[ 3.360265] handle_percpu_devid_irq from handle_irq_desc+0x50/0x80
[ 3.360297] handle_irq_desc from gic_handle_irq+0x88/0xa8
[ 3.360322] gic_handle_irq from generic_handle_arch_irq+0x34/0x44
[ 3.360352] generic_handle_arch_irq from __irq_svc+0x88/0xb0
[ 3.360379] Exception stack(0xc1d01f20 to 0xc1d01f68)
[ 3.360397] 1f20: 00109e0c 00000001 00000000 00000000 c1d09800 c1f74d04 c1d04d58 c1d04db4
[ 3.360412] 1f40: 00000000 00000000 c1bcfa60 00000000 c1f745d8 c1d01f70 c1261aec c1262eac
[ 3.360421] 1f60: 60000013 ffffffff
[ 3.360429] __irq_svc from default_idle_call+0x1c/0xb0
[ 3.360458] default_idle_call from do_idle+0x208/0x290
[ 3.360493] do_idle from cpu_startup_entry+0x28/0x2c
[ 3.360518] cpu_startup_entry from rest_init+0xac/0xb0
[ 3.360549] rest_init from arch_post_acpi_subsys_init+0x0/0x8
[ 3.477262] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
2026-05-24 7:13 AM
[ 3.119114] stm32_rtc 5c004000.rtc: registered as rtc0
[ 3.122877] stm32_rtc 5c004000.rtc: setting system clock to 2000-01-01T00:23:19 UTC (946686199)
[ 3.132134] stm32_rtc 5c004000.rtc: Date/Time must be initialized
[ 3.137693] stm32_rtc 5c004000.rtc: registered rev:1.2
[ 3.181946] clk: Disabling unused clocks
[ 3.184564] Warning: unable to open an initial console.
D/TC:1 pm_domain_scv_handler:23 Enable PD 2
[ 3.193879] Freeing unused kernel image (initmem) memory: 2048K
D/TC:1 pm_domain_scv_handler:23 Enable PD 1
[ 3.205824] Run /init as init process
D/TC:0 1 stat_handle_fault:1740 nfaults 29696 npages 13 (min 13)
[ 13.405788] platform 5c002000.i2c: deferred probe pending
[ 13.409853] platform 50028000.thermal: deferred probe pending
[ 13.415497] platform stm32-cpufreq: deferred probe pending
[ 13.421037] platform led: deferred probe pending
[ 13.425592] platform soc:pinctrl@50002000: deferred probe pending
[ 13.431717] platform soc:pinctrl@54004000: deferred probe pending
[ 13.437800] platform 48002000.dma-router: deferred probe pending
[ 13.443782] platform 48000000.dma-controller: deferred probe pending
[ 13.450151] platform 48001000.dma-controller: deferred probe pending
[ 13.456507] platform 58000000.dma-controller: deferred probe pending
[ 13.462842] platform 40010000.serial: deferred probe pending
[ 13.468513] platform 50001000.pwr: deferred probe pending
[ 13.473896] amba 58005000.mmc: deferred probe pending
new question, help me
