2020-10-29 4:54 AM
I use STM32MP151CAA3 Cortex-M4 on my custom board.
I got fault report from uVision debugger when __main called in my startup assembler code.
https://www.keil.com/support/man/docs/uv4/uv4_cp_m347_faults.htm
Memory Manage Faults DACCVIOL (Data access violation flag) are checked.
SCB->MMFAR ( Mem Manage Fault Address Register located at memory address 0xE000ED34) shows 0x10060000.
The address is region that Cortex-M4 cannot access, so I'm not accessing that region in my program.
Why above fault report occurs?
How can I investigate the cause of the Fault Reports?
Best Regards.
H. Masuda
2020-11-05 7:20 AM
Hi @HMasu.1 ,
I know there some "tips and tricks" for proper usage of Keil on top of MP1.
Did you get a look to https://www.keil.com/appnotes/files/apnt_319_v1.1.pdf ?
If you don't find solution here, please comment here detailing Keil and ST-Link version.
Olivier
2020-11-08 10:24 PM
Hi @Community member ,
Thank you for your reply.
I have seen this page, and I have set settings on uVison according to this page.
But I didn't find solution.
The Keil version is as followed.
I'm using ULINK Pro D debugger instead of ST-Link.
μVision V5.28.0.0
Tool Version Numbers:
Toolchain: MDK-ARM Essential Version: 5.28.0.0
C Compiler: Armcc.exe V5.06 update 6 (build 750)
Assembler: Armasm.exe V5.06 update 6 (build 750)
Linker/Locator: ArmLink.exe V5.06 update 6 (build 750)
Library Manager: ArmAr.exe V5.06 update 6 (build 750)
Hex Converter: FromElf.exe V5.06 update 6 (build 750)
CPU DLL: SARMCM3.DLL V5.28.0.0
Dialog DLL: TCM.DLL V1.36.2.0
Target DLL: ULP2CM3.DLL V2.211.20.0
Best Regards.
H. Masuda
