2020-10-16 6:54 AM
Good afternoon. I tried to check your example OpanAMP_TTY_echo together with the ssh-t ttyRPMSG0 command after trying to execute the ssh-t ttyRPMSG0 command, the terminal responds Error resolving ttyRPMSG0 port 22 Temporary failure in name resolution Why? What did I do wrong? Sincerely, Alexander
2020-10-26 9:23 AM
Hi @Vlaty.1
Can you better explain what you are trying to achieve ?
ttyRPMSG0 is used to exchange message/data between A7 and M4.
From where did you try to connect with ssh-t ttyRPMSG0 ?
Olivier
2020-10-27 2:03 AM
