2024-05-23 10:31 PM
I follow this guide X-LINUX-AWS Expansion Package
cmd) aws iot attach-policy --policy-name ${TOKEN_EXCHANGE_ROLE_ALIAS_POLICY} --target ${CERT_ARN}
but, error occurred (ResourceNotFoundException) when calling the AttachPolicy operation: Policy not found
PC)
yhlee@YoungHan:~/STM32MPU_workspace$ scp root@${BOARD_IP}:${CSR} ${CSR_ON_PC}
mykey_csr.pem 100% 899 484.7KB/s 00:00
-certificate-from-csr --certificate-signing-request file://${CSR_ON_PC} --certificate-pem-outfile ${CERT_ON_PC} --set-as-active
scp ${CERT_ON_PC} root@${BOARD_IP}:${CERT}
mykey_csr.pem 100% 899 427.4KB/s 00:00
yhlee@YoungHan:~/STM32MPU_workspace$ aws iot create-certificate-from-csr --certificate-signing-request file://${CSR_ON_PC} --certificate-pem-outfile ${CERT_ON_PC} --set-as-active
"certificateArn": "arn:aws:iot:ap-northeast-2:590183762918:cert/689ea30a84b838d89f8b06458b33deee0ad11a9c348caa015ebb7f670e90f045",
"certificateId": "689ea30a84b838d89f8b06458b33deee0ad11a9c348caa015ebb7f670e90f045",
"certificatePem": "-----BEGIN CERTIFICATE-----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\np8Hzv2K+7uj3pyRoPtcXwNTUsV+0EO2+BgbAth1gj3L3HKDJt8r+g6Dv\n-----END CERTIFICATE-----\n"
yhlee@YoungHan:~/STM32MPU_workspace$ scp ${CERT_ON_PC} root@${BOARD_IP}:${CERT}
core.pem 100% 1216 427.6KB/s 00:00
yhlee@YoungHan:~/STM32MPU_workspace$ CERT_ARN="arn:aws:iot:ap-northeast-2:590183762918:cert/689ea30a84b838d89f8b06458b33deee0ad11a9c348caa015ebb7f670
e90f045"
yhlee@YoungHan:~/STM32MPU_workspace$ aws iot attach-thing-principal --thing-name ${GREENGRASS_CORE} --principal ${CERT_ARN}
yhlee@YoungHan:~/STM32MPU_workspace$ aws iot attach-policy --policy-name ${AWS_IOT_POLICY} --target ${CERT_ARN}
yhlee@YoungHan:~/STM32MPU_workspace$ aws iot attach-policy --policy-name ${TOKEN_EXCHANGE_ROLE_ALIAS_POLICY} --target ${CERT_ARN}
An error occurred (ResourceNotFoundException) when calling the AttachPolicy operation: Policy not found
2024-05-24 12:28 AM
Hello @younghan,
As mentioned in X-LINUX-AWS (section AWS IoT and IAM resources configuration) you must have create several resources on AWS, especially a Token Exchange Role Alias Policy.
It seems that this resource has not been created. You can follow the steps of greengrass v2 create-token-exchange-role
All the steps need to be done
Finally you command
aws iot attach-policy --policy-name GreengrassCoreTokenExchangeRoleAliasPolicy --target arn:aws:iot:us-west-2:123456789012:cert/aa0b7958770878eabe251d8a7ddd547f4889c524c9b574ab9fbf65f32248b1d4should work.
Best regards,
2024-05-24 12:28 AM
Hello @younghan,
Finally you command
Best regards,
