2019-02-09 9:56 AM
System:
Distributor ID: Ubuntu
Description: Ubuntu 18.04.1 LTS
Release: 18.04
Codename: bionicJava version:
java version "1.8.0_201"
Java(TM) SE Runtime Environment (build 1.8.0_201-b09)
Java HotSpot(TM) 64-Bit Server VM (build 25.201-b09, mixed mode)Cube:
chdir /home/jdoe/Tools/STM32CubeMX/.
current dir /home/jdoe/Tools/STM32CubeMX
log4j user configuration file not found: /home/jdoe/.stm32cubemx/log4j.properties
Configure log4j with default settings from jar:file:/home/jdoe/Tools/STM32CubeMX/STM32CubeMX!/log4j/log4j.stm32cubemx.properties
2019-02-09 18:50:35,015 [INFO] MicroXplorer:486 - Detected Java Version = 1.8.0_201
2019-02-09 18:50:35,023 [INFO] ApplicationProperties:181 - Using Application install path: /home/jdoe/Tools/STM32CubeMX
2019-02-09 18:50:35,040 [INFO] DbMcusXml:68 - Set database path to: /home/jdoe/Tools/STM32CubeMX//db//mcu/
2019-02-09 18:50:35,046 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/boardmanager/
2019-02-09 18:50:35,047 [INFO] DbMcus:262 - Set plugin images path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/mcufinder/images/
2019-02-09 18:50:35,047 [INFO] DbBoards:224 - Set plugin images path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/mcufinder/images/
2019-02-09 18:50:35,050 [INFO] APIGFXSelector:72 - Set database path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/mcufinder/mcu/
2019-02-09 18:50:35,109 [WARN] ApiFinderProperties:107 - /home/jdoe/.stmcufinder/plugins/mcufinder/mcu/mcuFinder.mfd doesn't exist
2019-02-09 18:50:35,113 [INFO] DbMcusAds:72 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,114 [INFO] DbMcusDocs:90 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,117 [INFO] DbMcusJson:58 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,119 [INFO] DbBoardsDocs:82 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,121 [INFO] DbBoardsJson:51 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,138 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,327 [INFO] RulesReader:53 - Compatibility file has been processed (127 Rules)
2019-02-09 18:50:35,373 [INFO] STM32CubeMX:31 - Starting STM32CubeMX
2019-02-09 18:50:35,650 [INFO] MainPanel:139 - HeapMemory: 251658240
2019-02-09 18:50:35,825 [INFO] DbMcusXml:68 - Set database path to: /home/jdoe/Tools/STM32CubeMX//db//mcu/
2019-02-09 18:50:35,826 [INFO] DbBoardsPdsc:54 - Set plugin database path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/boardmanager/
2019-02-09 18:50:35,826 [INFO] DbMcus:262 - Set plugin images path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/mcufinder/images/
2019-02-09 18:50:35,826 [INFO] DbBoards:224 - Set plugin images path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/mcufinder/images/
2019-02-09 18:50:35,826 [INFO] APIGFXSelector:72 - Set database path to: /home/jdoe/Tools/STM32CubeMX//db//plugins/mcufinder/mcu/
2019-02-09 18:50:35,827 [WARN] DbFile:31 - Overriding database path with different value: /home/jdoe/.stmcufinder/plugins/mcufinder/ => /home/jdoe/.stmcufinder/plugins/mcufinder
2019-02-09 18:50:35,827 [INFO] DbMcusAds:72 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,828 [WARN] DbFile:31 - Overriding database path with different value: /home/jdoe/.stmcufinder/plugins/mcufinder/ => /home/jdoe/.stmcufinder/plugins/mcufinder
2019-02-09 18:50:35,828 [INFO] DbMcusDocs:90 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,828 [INFO] DbMcusJson:58 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,829 [INFO] DbBoardsDocs:82 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,829 [WARN] DbFile:31 - Overriding database path with different value: /home/jdoe/.stmcufinder/plugins/mcufinder/ => /home/jdoe/.stmcufinder/plugins/mcufinder
2019-02-09 18:50:35,829 [INFO] DbBoardsJson:51 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,830 [WARN] DbFile:31 - Overriding database path with different value: /home/jdoe/.stmcufinder/plugins/mcufinder/ => /home/jdoe/.stmcufinder/plugins/mcufinder
2019-02-09 18:50:35,830 [INFO] CrossReferenceDbSqlite:197 - Set database path to: /home/jdoe/.stmcufinder/plugins/mcufinder//mcu/
2019-02-09 18:50:35,870 [INFO] ApplicationProperties:181 - Using Application install path: /home/jdoe/Tools/STM32CubeMX
2019-02-09 18:50:35,872 [INFO] PluginManage:167 - Search for loadable plugins [exclusion list=]
2019-02-09 18:50:35,874 [INFO] PluginManage:289 - Check plugin analytics
2019-02-09 18:50:36,147 [INFO] UserProfileFactory:23 - /com/st/library/analyticscore
2019-02-09 18:50:36,165 [INFO] UserProfileFactory:25 - aa36af13_4f49_4a23_8fb0_22a182c3e241
2019-02-09 18:50:36,191 [INFO] AnalyticsPlugin:190 - Accepted Software Licenses: STM32CubeMX.5.0.1
2019-02-09 18:50:36,191 [INFO] AnalyticsPlugin:192 - Accepted CMSIS Pack Licenses:
2019-02-09 18:50:36,192 [INFO] AnalyticsPlugin:194 - Accepted Firmware Licenses:
2019-02-09 18:50:36,192 [INFO] PluginManage:339 - Loaded plugin analytics (category:tool,tabindex:-1)
2019-02-09 18:50:36,193 [INFO] PluginManage:289 - Check plugin filemanager
2019-02-09 18:50:36,452 [INFO] PluginManage:339 - Loaded plugin filemanager (category:base,tabindex:10)
2019-02-09 18:50:36,453 [INFO] PluginManage:289 - Check plugin thirdparty
2019-02-09 18:50:36,475 [INFO] ThirdPartyDb:293 - Open Third Party DataBase File (/home/jdoe/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml) : 0 ms. number of Sw pack : 0
2019-02-09 18:50:36,489 [INFO] PluginManage:339 - Loaded plugin thirdparty (category:base,tabindex:-1)
2019-02-09 18:50:36,489 [INFO] PluginManage:289 - Check plugin pinoutandconfiguration
2019-02-09 18:50:36,498 [INFO] PluginManage:339 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2019-02-09 18:50:36,498 [INFO] PluginManage:289 - Check plugin power
2019-02-09 18:50:36,537 [INFO] PluginManage:339 - Loaded plugin power (category:power,tabindex:4)
2019-02-09 18:50:36,537 [INFO] PluginManage:289 - Check plugin tools
2019-02-09 18:50:36,539 [INFO] PluginManage:339 - Loaded plugin tools (category:base,tabindex:5)
2019-02-09 18:50:36,539 [INFO] PluginManage:289 - Check plugin ipmanager
2019-02-09 18:50:36,546 [INFO] PluginManage:339 - Loaded plugin ipmanager (category:base,tabindex:5)
2019-02-09 18:50:36,547 [INFO] PluginManage:289 - Check plugin projectmanager
2019-02-09 18:50:36,592 [INFO] PluginManage:339 - Loaded plugin projectmanager (category:projectmanager,tabindex:3)
2019-02-09 18:50:36,592 [INFO] PluginManage:289 - Check plugin pinoutconfig
2019-02-09 18:50:36,614 [INFO] PluginManage:339 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2019-02-09 18:50:36,614 [INFO] PluginManage:289 - Check plugin updater
2019-02-09 18:50:36,634 [INFO] PluginManage:339 - Loaded plugin updater (category:base,tabindex:12)
2019-02-09 18:50:36,635 [INFO] PluginManage:289 - Check plugin clock
2019-02-09 18:50:36,649 [INFO] PluginManage:339 - Loaded plugin clock (category:base,tabindex:2)
2019-02-09 18:51:21,489 [ERROR] IntegrityCheckThread:90 - Cannot obtain updater plugin
2019-02-09 18:51:21,489 [INFO] IntegrityCheckThread:94 - End integrity checks thread
2019-02-09 18:51:21,489 [INFO] ThirdPartyDb:263 - Close Third Party DataBase File (/home/jdoe/.stm32cubemx/plugins/thirdparty/db/thirdparties_db.xml)
