2020-06-10 6:57 AM
Dear ST community,
I’m trying to use the distribution package as described in the guide https://wiki.st.com/stm32mpu/wiki/STM32MP1_Distribution_Package#Installing_the_OpenSTLinux_distribution, but the oe-init-build-env file is absent.
The first commands:
$ repo init -u https://github.com/STMicroelectronics/oe-manifest.git -b refs/tags/openstlinux-20-02-19
And
$ repo sync
Finish successfully.
However when I initialize the OpenEmbedded build environment (chapter 5.1):
PC $> DISTRO=openstlinux-weston MACHINE=stm32mp1 source layers/meta-st/scripts/envsetup.sh
The command fails due to the missing of the oe-init-build-env file.
I check the revision of the openembedded-core folder and it is cd7cf933b3235560ec71576d8f3836dff736a39f as indicated in the manifest (https://github.com/STMicroelectronics/oe-manifest/blob/thud/default.xml), however inside the openembedded-core folder there is no oe-init-build-env file.
How can I solve this problem?.
Thanks in advance for any suggestions.
2020-06-11 9:24 AM
Hi @Ma2teo
This may come from your environment.
Did you install all extra packages recommended in https://wiki.st.com/stm32mpu/wiki/PC_prerequisites#Install_extra_packages ?
Hope it help
Olivier
2020-06-12 9:30 AM
Hi @Community member ,
Thanks for your attention to this matter.
Your suggestion has worked.
I have followed again the indications reported at that link.
I have reinstalled again all the required packages and tools.
Now my layers/embedded-core folder is populated with a lot of folders and files including the oe-init-build-env file.
Probably something wasn’t correctly installed in my previous attempt.
Thanks again.
