2021-04-22 1:56 AM
Hello ST Teams!
I'd like to know if someone have ever tried to get 1920*1080*30fps with the configuration above (STM32MP157C-EV1 and MB1379 board).
We'd like to achieve this performance, OV5640 datasheet camera says "ok for me"
v4l2 listing capabilities says "ok for me" :
Size: Discrete 1920x1080
Interval: Discrete 0.067s (15.000 fps)
Interval: Discrete 0.033s (30.000 fps)
But if we try with dev board (OSD32BRK) and flying wires with camera(OV5640), fps is limited to 13fps.
My question is: Is it possible to achieve 30fps in this configuration?
we will reproduce schematics of (STM32MP157C-EV1 and MB1379 board) camera part
(dcmi + ext clk ) , but we're not sure of fps performance .
from: "dm00693021-stm32mp1-series-interfacing-with-a-mipi-csi2-camera-stmicroelectronics.pdf" (okay its using he STMIPID02 but commands are the same)
root@stm32mp1-av96:~# v4l2-ctl --set-parm=30;
root@stm32mp1-av96:~# v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RGBP --stream-mmap --stream-count=-1
Can someone try it ?
2021-06-18 6:47 AM
Hello Eldam (Community Member),
The Maximum DCMI performance that can be acheived with the STM32MP157 is 24Mpix/s with 16 bits per pixel using 8 bits parallel bus.
Therefore 13 fps that you've found for 1920x1080 resolution is correct.
Regards,
Olivier
2021-06-18 6:47 AM
Regards,
Olivier
2021-06-20 11:45 PM
Hello Olivier,
Thanks for answering me.
By the time, we have been able to get 30fps by lowering resolution.
Have nice summer holidays!
