STM32CubeIDE for VS Code debug configuration (launch.json)
Nawres GHARBI
Summary
This article details the configuration options for debugging STM32 projects in VS Code using the STM32CubeIDE extension.
These are the three main debug configurations that you may need with STM32CubeIDE for VS Code extension.
1. STM32Cube: STM32 launch STLINK GDB server
Type: "stlinkgdbtarget"
  • Uses the STLINK GDB server (provided by STM32CubeProgrammer).
  • Suitable for official STLINK hardware probes.
Key parameters:
Parameter Type Description
type string Must be "stlinkgdbtarget". Specifies the debugger type.
request string "launch" to start a new debug session, or "attach" to connect to a running target.
name string User-friendly configuration name
cwd string Working directory for the debug session.
preBuild string Command to run before starting the debug session (for example, build task).
runEntry string Entry point symbol to run to after reset (for example, "main").
serverExtLoader array List of external loader objects for external flash (see below for object structure).
imagesAndSymbols array List of objects specifying images (binaries) and their symbols to load (see below).
device string STM32 device part number (optional, for example, "STM32H7R3ZI").
interface string Debug interface, typically "swd" or "jtag" (optional).
stopAtEntry boolean If true, stops at the entry point after reset (optional).
svdFile string Path to SVD file for peripheral register view (optional).
serverArgs array Additional arguments to pass to the STLINK GDB server (optional).
gdbPath string Path to the GDB executable (optional).
gdbArgs array Additional arguments for GDB (optional).
postRestartCmds array GDB commands to execute after restart (optional).
postAttachCmds array GDB commands to execute after attach (optional).
serverExtLoader object:
Field Type Description
loader string Path to the external loader file (.stldr).
initialize boolean Whether to initialize the loader at session start.
imagesAndSymbols object:
imageFileName string Path to the binary/ELF file to load.
symbolsFileName string Path to the symbols file (optional, if separate from image).
2. STM32Cube: STM32 launch OpenOCD
Type: "openocdtarget"
  • Uses OpenOCD as the debug server.
  • Flexible for various debug probes and custom scripts.
Key parameters:
type string Must be "openocdtarget". Specifies the debugger type.
request string "launch" or "attach".
name string User-friendly configuration name.
preBuild string Command to run before starting the debug session.
openOCDConfigFiles array List of OpenOCD config files (for example, interface, target, board).
openOCDSearchDirs array Directories to search for OpenOCD scripts.
imagesAndSymbols array List of objects specifying images (binaries) and their symbols to load.
device string STM32 device part number (optional).
serverArgs array Additional arguments to pass to OpenOCD (optional).
3. STM32Cube: STM32 launch J-Link GDB server
Type: "jlinkgdbtarget"
  • Uses SEGGER J-Link GDB server.
  • For SEGGER J-Link hardware probes.
Key Parameters:
type string Must be "jlinkgdbtarget". Specifies the debugger type.
jlinkDevice string Device name for J-Link (for example, "STM32H7R3ZI").
interface string Debug interface, typically "swd" or "jtag".
serverArgs array Additional arguments to pass to the J-Link GDB server (optional).
3.1 Notes
  • The "type" field determines the debug server: "stlinkgdbtarget", "openocdtarget",  "jlinkgdbtarget"or other type.
  • Use "serverExtLoader" for external flash loaders if needed.
  • "imagesAndSymbols" allows specifying multiple binaries or symbol files.
  • Adjust "preBuild", "cwd", and other fields as needed for your project.
4. Examples
4.1 STM32 STLINK GDB server
  "type": "stlinkgdbtarget",
  "request": "launch",
  "name": "STM32Cube: STM32 Launch ST-Link GDB Server",
  "cwd": "${workspaceFolder}",
  "preBuild": "${command:st-stm32-ide-debug-launch.build}",
  "runEntry": "main",
  "serverExtLoader": [
      "loader": "C:/Users/gharbin/AppData/Local/stm32cube/bundles/programmer/2.21.0-a10/bin/ExternalLoader/MX25UW25645G_NUCLEO-H7S3L8.stldr",
      "initialize": false
  "imagesAndSymbols": [
      "imageFileName": "${command:st-stm32-ide-debug-launch.get-projects-binary-from-context1}"
      "imageFileName": "${command:st-stm32-ide-debug-launch.get-projects-binary-from-context2}"
  "device": "STM32H7R3ZI",
  "interface": "swd",
  "stopAtEntry": false,
  "svdFile": "${workspaceFolder}/Drivers/CMSIS/Device/ST/STM32H7RSxx/Include/STM32H7R3.svd"
4.2 STM32 J-Link GDB server
  "type": "jlinkgdbtarget",
  "name": "STM32Cube: STM32 Launch J-Link GDB Server",
  "jlinkDevice": "STM32H7R3ZI",
  "interface": "swd",
  "runEntry": "main",
4.3 STM32 OpenOCD
  "type": "openocdtarget",
  "name": "STM32Cube: STM32 Launch OpenOCD",
  "openOCDConfigFiles": [
    "interface/stlink.cfg",
    "target/stm32h7x.cfg"
  "openOCDSearchDirs": [
    "C:/OpenOCD/scripts"
  "runEntry": "main",
  "interface": "swd",
5. Tips
5.1 How to debug a secure project
  1. Create a launch.json.
  2. Add a second image to be loaded.
  3. Change the context for the new created image.
  4. When launching the debug, the selected bin must follow the order nonsecure then secure.
  5. Save your presets for later use if needed.
5.2 How to debug a dual-core project (for example, STM32H7)
  2. Add a new image context and change its number for the second binary to be loaded.
  3. Add "serverShared" parameter with the value set as true.
  4. Add "serverHaltAllCores" parameter with the value set as true.
This configuration is dedicated to the CM7 core.
Let us create a new configuration for the CM4 core.
  1. Create another config by pressing the [add configuration] button displayed in the launch.json.
  2. Remove the existing image and replace it by a symbol file name parameter as the second configuration will be used for attaching debug without flashing the device.
  3. Add server shared parameter with the value set as true.
  4. Add the server AP ID with value 3, which represents the port ID for the CM4 core.
  5. Add the server port with 61239 value for the GDB port for the second core.
  6. Set the reset value to “none” to avoid resetting the core while attaching to it.
  7. For the flashing order requested by the debugger (CM7 config), select the first one to start as the latest one to be flashed, in this case you select CM4, then CM7.
  8. For the second configuration (CM4) select the CM4 binary to load the symbols from it.
The order of debug launch will be:
  1. Launch the CM7 debug
  2. Launch the CM4 debug
5.3 How to debug a project with an external loader
  1. In your current launch.json, add a "serverExtLoader" parameter to configure the external loader.
  2. Add "loader" in "serverExtLoader" and set the extloader path.
  3. Keep "initialize" set to false.
5.4 Advanced debug launch configuration tips
  • Attach without reset
    Reset mode “none”
    ImageAndSymbols: only SymbolFileName
  • Reset mode control
    "serverReset": "Connect under reset",​
  • TCP Console (semihosting)
    "serverSemihosting": {
            "enabled": true,
            "mode": "console",
            "port": "61260" },​
  • liveWatch
    "liveWatch": {
        "enabled": true,
        "samplesPerSecond": "4" },​
  • Prebuild command
    "preBuild": "${command:st-stm32-ide-debug-launch.build}",​
  • RTOS view
    "serverRtos": {
          "enabled": true,
          "port":"60000",
          "driver": "freertos" }​
5. Support
For support, visit our VS Code product forums:
STM32CubeIDE for Visual Studio Code product forums.
Related links
STM32Cube for VS Code
Comments
fritz3917
Associate
I'm having lots of problems getting the STLink debugger working in my project using an STM32G0 processor. Apparently the "launch.json file is not correct. Is there any way in the future to automate this. Like maybe have a command that automatically sets the json file up for debug. It's a real pain having to edit the jason file by hand and also having to add new C files to the cmakelists.txt. Everything else seems to work great.
giro
Associate
For me STM32 STLINK GDB server kind of worked (after pointing the files in the right direction) although device, interface, stopAtEntry and svdFile are not allowed in my launch.json file.
Version history
Last update:
‎2026-02-16 6:28 AM
Updated by:
