STM32WL55CC LPUART1 to UART1 freeze
MLam
Associate III
Hello everyone,
I work on a project with LSM100A whitch integrate an STM32WL55CC.
I have an SDK available to start development and in this SDK, we can find debug information on LPUART 1 (PA2,PA3).
For my project, i can't use LPUART1 so i have decided to use UART1 on PB6 and PB7. So i have modified SDK to transform LPUART1 configuration into UART1 config.
I have this following result, only the first message is printed and in this first message missing the first letter.
I have try multiple things and i think that the problem turn around interrupt but i don't have find any solution.
I join my project if you want to understand better my problem.
Do you have advice or maybe have you already meet this problem ?
Thansk for your help,
Best Regards,
MLam,
2 REPLIES 2
Louis AUDOLY
You can find UART examples (with DMA, Polling) in the STM32Cube_FW_WL_V1.2.0 under Projects\NUCLEO-WL55JC\Examples\UART to verify your configuration.
For the first letter you miss, can you check your Terminal configuration that could cause your issue (if the terminal expect to receive just /n or /r it could lead to some unexpected behaviors.
Let me know if it solve your issue
MLam
Associate III
Thanks for the return,
I will check the informations that you send and let you know if it's solve the issue.
best regards,
MLam
