2023-06-27 3:06 AM
Hi there,
I have a couple of these boards hooked up to TTN indoor gateway. However after swapping batteries one of them is not joining the network despite using the same files/firmware. Looking at the serial readout, I don't see the usual "Joined = OTAA", just the "MCPS-Confirm" loops, which look the same as the others.
Any ideas what could be happening?
Kind regards,
Oliver
2023-07-07 9:19 AM
Hello @ollyole and welcome to the ST Community.
I suggest you to :
I hope this is helpful for you
Issam
