2024-08-17 2:10 PM
We created an empty C++ project. Then, added some web-sourced .cpp and .hpp code into the directory. Compiled and debugged with ST-Link MiniE fine. Entry is main.cpp
In STM32CubeIDE, click .ioc and edit init code with STM32MX. STM32MX generates main.c instead of main.cpp where our code resides.
Many thanks
2024-08-17 5:04 PM
This is the intended behavior. There is no problem with C and C++ files in the same project, and HAL is designed in C.
If you want to run a C++ function from within main.c, define it with extern "C" and call it normally. Calling a C++ main loop function right before the main loop in main.c is common.
2024-08-17 5:04 PM
