2025-07-10 5:59 AM
"Can someone please check this code? It's for normal LoRa point-to-point (P2P) communication. I’ve attached the file with this post. The problem I'm facing is that a software interrupt is supposed to occur every second and trigger my scheduled task — but it's not happening. Please help me fix it."
2025-08-05 2:40 AM
Hello @avinashkumar
I suggest you have a look at this tutorial. It should help you for this implementation.
Best Regards.
STTwo-32
2025-07-10 6:07 AM
You need to give some more details - see: How to write your question to maximize your chances to find a solution.
2025-08-05 2:40 AM
Hello @avinashkumar
Best Regards.
STTwo-32
