2021-07-27 7:35 AM
2021-07-27 8:26 AM
Hello @Snara.2
Please have a look at the AN5289 Application note Building wireless applications with STM32WB Series microcontrollers.
You can also refer to the attached presentation, demonstrating how to use our STM32CubeMX for starting your BLE application project for the STM32WB module discovery kit.
Hope this helps you!
Please select my answer as Best if it fully answered your question, so that this thread will marked as solved.
Imen
2021-07-27 8:26 AM
Depends of the sensor, if its one of those dammed HeartMonitors or temperature sensors youre in luck because there is plenty of working examples already.
2021-07-31 7:05 AM
@Imen DAHMEN . I have gone thro the presentation. The steps we see in the presentation is not seen, If I select the STELVAL_MKSBOXV1
The step by step procedure shows as follows but not seen in the Cube MX
