2025-01-31 12:45 AM - last edited on 2025-01-31 1:11 AM by STTwo-32
Hi there!
I'm just starting with the B-WL5M-SUBG1 and would like the source code for the program that runs on a newly purchased development board. The documentation says this code is available https://www.st.com/resource/en/data_brief/b-wl5m-subg1.pdf section 2.3.
However, I've searched and cannot find it anywhere. Can someone help?
Here's the application output:
Many thanks!
David
2025-01-31 1:03 AM - edited 2025-01-31 1:04 AM
Hello @davidn ,
You can find the demo by downloading the latest package from the ST.com website (not from GitHub). Follow this path: STM32Cube_FW_WL_V1.3.0\Projects\B-WL5M-SUBG1\Demonstrations. You will find the B-WL5M-SUBG1 demo there.
Regards ,
2025-01-31 4:12 AM
Hello @MOBEJ
I've looked through the code on the Demonstration sample you advised. It does'nt look like it produces the output (on the screenshot). The software running on my board looks like a comprehensive test system.
Could you check again?
Thank you
David
