2023-09-03 11:06 PM
when i generate the adc based code then it show the error without doing anything in the main code
2023-09-04 3:51 AM
reason is this that there is no driver of adc ,so copy from another folder and paste in this code,so now working
2023-09-03 11:22 PM - edited 2023-09-03 11:24 PM
Hello @Ranjeet Singh
Can you add the code you are using, your firmware version and your CubeIDE and CubeMX version to make it easier to find the problem.
Best regards.
II
2023-09-04 1:20 AM
code is bydefault generated
2023-09-04 3:17 AM
I suggest you change the directory file and regenerate the code.
Best regards.
II
2023-09-04 3:51 AM
2023-09-04 3:55 AM
If your question is answered please check the solution as best answer to be diffused to everyone.
Best regards.
II
2023-09-04 3:57 AM
i have another problem ,live debugging not work, it say target not found
