2020-12-16 12:17 PM
I remember reading (or hearing) that there was a place to go and get widgets (Git maybe) either to use as is or as a starting point for your own use.
However, I can find no reference to anything like that anymore. I found a Git that appeared to be an open-source repository for widgets but the content has been removed.
Can anyone shed some light on a widget repository?
Thanks,
Keith
2020-12-18 12:54 AM
You can find the code for the widgets provided in TouchGFX Designer through the generated code in your project. I am not aware of a git repository for widgets, there used to be one for old UI examples but it was taken down since those examples are available in Designer though "UI template".
/Romain
