2019-12-26 12:25 AM
My first simplest touchGFX application can run on my st board.
Now, I changed some UI with Designer and generate code, the BoardConfiguration.cpp need to be re-compiled, otherwise, an error generated at run time with message as "View allocation error: Check that all views are added to FrontendHeap::ViewTypes".
My project is big, so I separate the hardware driver from the UI code as a lib file. I think, BoardConfiguration.cpp should only rely on hardware and has nothing to do with final UI code.
So, can I separate final UI related things (memory size I guess) from BoardConfiguration, and put it at the app initialization section.
