2022-06-15 5:00 AM
This error was raised using Touchgfx 4.19.1, CubeMX 6.5. Nothing interesting in the project, just the default settings of Nucleo f446re, adding gfx software pack and adding a clock in the designer -> generate code and compile in CubeIDE and again in uVision. Same error and I cannot find this file searching the file explorer ! Your help is much appreciated.
2022-06-16 6:19 AM
I've re-installed touchgfx from cubemx and started a project properly from the cubemx then initiated the designer from the generated code, this solved the problem. Please accept my apologies for wasting your time.
2022-06-16 6:19 AM
2022-06-23 5:09 AM
Hi ksale.1,
Great to hear your problem is solved. Remember to always regenerate from TouchGFX after generating from STM32CubeMX, and only then you can compile.
/Osman
