2023-08-14 10:46 PM
Like topic i can compiler demo code successfully and "run" simulator.exe, but result console will closed immediately, i only can use virtual studio 2019 open the "simulator.exe" and press debug then i can see the result, any good suggestion that i can do?
i already tried reinstall TouchGFX and VS2019, Or use admin excute TouchGFX, but it useless.
2023-09-14 3:28 AM
Hello @Mercy ,
Are you trying to run a demo which is exported from the designer or is it your custom project? If it's from designer, could you specify which demo you are trying to have the simulation?
