2014-02-13 7:00 PM
It appears as though the TFT Displays VSYNC signal (pa4) is in use in RGB-mode, and as a result, I can't set it to function as AFIO DAC&sharp1 output (pa4), as it seems to cause the display to turn all white. DAC&sharp2 output (pa5) works ok, but I was hoping to get a stereo output using both DAC pins. Can the TFT be set to run in MCU-mode, or any other mode that does not require a VSYNC signal?
#dac #tft #discovery-stm32f429Solved! Go to Solution.
2014-02-14 8:23 AM
2014-02-14 8:23 AM
