2021-09-22 2:26 AM
I am Venket Raj , Junior Design engineer, I am currently using STM32F769I-DISCO with ST7796S Display Driver. The ST7796S uses MIPI-DSI Protocol for its communication . I have to know that any support driver available for this.
Also if any other way to test the display functionality by means of any test code.Kindly provide .
I am writing the Display driver for ST7796S reference with the OTM8009a driver, which the driver is working currently. Most of the initialisation address are same.
****Custom Display (PV154006LF24E) which I am currently having only the MIPI_DSI Interface.*****
I have attached the datasheets of the abov(ST7796S and OTM8009a ) . Also attached the Initialisation code which sent by the manufacturer, which is not elaborate.
Kindly Help me in this regard... I am stuck in this for a long time which makes more critical to me.
2022-12-10 12:37 AM
Hi VS.6,
I'm facing the same issue - do you have any updates regarding this issue?
Can you share the ST7796S driver you use?
Thanks in advance.
