2020-09-24 1:21 AM
Generate Code
Generate
Done
Generate Assets
make -f simulator/gcc/Makefile assets -j8
The system cannot find the path specified.
Converting images
Reading ./application.config
Failed
Failed
AND FROM COMMAND LINE after make -f simulator/gcc/Makefile
Igenerated/texts/include -I../Middlewares/ST/touchgfx/framework/include -c gui/s
rc/easingequation_screen/EasingEquationGraph.cpp -o build/MINGW32_NT-6.2/gui/src
/easingequation_screen/EasingEquationGraph.o, ...) failed.
make (e=2): The system cannot find the file specified.
generated/simulator/gcc/Makefile:190: recipe for target 'build/MINGW32_NT-6.2/gu
i/src/easingequation_screen/EasingEquationGraph.o' failed
2020-09-25 6:07 AM
Could you elaborate the steps you did ? What version of TouchGFX do you have ? If it's not 4.14, please upgrade to 4.14.
/Alexandre
2020-10-04 11:39 AM
4.14.. It compiles in console but gives error in program. Looks like may be program does not change environment.. may be.. Steps: just load any demo and try to build simulator or generate code. It gives this...
2020-10-04 5:16 PM
This should definitely be not the case. TouchGFX should work using out of box demos without any problem.
Can you try reinstall it ?
Could you provide sequentially the steps you did even if it sounds obvious ?
So it compiles but you cannot run the simulator nor on the board ? What do you mean by "program does not change environment" ?
/Alexandre
2020-10-05 6:09 AM
Installed. Create new project for stm32. Open Imga example. Press Run Simulator. ANd get this:
Run Simulator
Copy Framework
Copying TouchGFX framework version 4.14.0 to C:\TouchGFXProjects\MyApplication\Middlewares\ST\touchgfx
Done
Generate
Wrote config/gcc/app.mk
Wrote config/msvs/Application.props
Wrote generated/gui_generated/include/gui_generated/common/FrontendApplicationBase.hpp
Wrote generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp
Wrote generated/gui_generated/include/gui_generated/common/SimConstants.hpp
Wrote generated/gui_generated/include/gui_generated/main_screen/MainViewBase.hpp
Wrote generated/gui_generated/src/common/FrontendApplicationBase.cpp
Wrote generated/gui_generated/src/main_screen/MainViewBase.cpp
Wrote generated/simulator/gcc/Makefile
Wrote generated/simulator/include/simulator/mainBase.hpp
Wrote generated/simulator/msvs/touchgfx.props
Wrote generated/simulator/msvs/touchgfx_prebuild.targets
Wrote generated/simulator/msvs/touchgfx_sdl2.props
Wrote generated/simulator/src/mainBase.cpp
Wrote generated/simulator/touchgfx.ico
Wrote generated/simulator/touchgfx.rc
Wrote generated/simulator/touchgfx.res
Wrote simulator/gcc/Makefile
Wrote simulator/main.cpp
Wrote simulator/msvs/Application.sln
Wrote simulator/msvs/Application.vcxproj
Wrote simulator/msvs/Application.vcxproj.filters
Done
Generate Assets
Generating generated/images/src/image_ani_01.cpp
Generating generated/images/src/image_ani_02.cpp
Generating generated/images/src/image_ani_03.cpp
Generating generated/images/src/image_ani_04.cpp
Generating generated/images/src/image_ani_05.cpp
Generating generated/images/src/image_ani_06.cpp
Generating generated/images/src/image_ani_07.cpp
Generating generated/images/src/image_ani_08.cpp
Generating generated/images/src/image_ani_09.cpp
Generating generated/images/src/image_ani_10.cpp
Generating generated/images/src/image_ani_11.cpp
Generating generated/images/src/image_ani_12.cpp
Generating generated/images/src/image_ani_13.cpp
Generating generated/images/src/image_ani_14.cpp
Generating generated/images/src/image_bg.cpp
Generating generated/images/src/image_btn.cpp
Generating generated/images/src/image_btn_pressed.cpp
Generating generated/images/include/BitmapDatabase.hpp
Generating generated/images/src/BitmapDatabase.cpp
Cleaning generated files from generated/texts and generated/fonts.
Generating generated/fonts/src/GeneratedFont.cpp
Generating generated/fonts/include/fonts/GeneratedFont.hpp
Generating generated/fonts/include/fonts/CachedFont.hpp
Generating generated/fonts/src/CachedFont.cpp
Generating generated/fonts/include/fonts/FontCache.hpp
Generating generated/fonts/src/FontCache.cpp
Generating generated/fonts/src/ApplicationFontProvider.cpp
Generating generated/fonts/include/fonts/ApplicationFontProvider.hpp
Generating generated/texts/include/texts/TextKeysAndLanguages.hpp
Generating generated/texts/include/texts/TypedTextDatabase.hpp
Generating generated/texts/src/TypedTextDatabase.cpp
Generating generated/texts/src/Texts.cpp
Generating generated/texts/src/LanguageGb.cpp
Failed
Failed
2020-10-05 7:08 PM
"Create new project for stm32. Open Imga example."
Create project where ? How ? What is lmga example ?
Unfortunately, what you gave me does not help trying to find out the issue. Try to be more precise.
/Alexandre
2020-10-06 12:32 AM
2020-10-06 6:22 PM
What template ? Image Example does not exist but I suppose you are talking about the Animated Image Example.
Here are the steps I did and it worked :
I need more information to understand your problem. But first try to reinstall TouchGFX and do the steps I did.
/Alexandre
2020-10-07 12:35 AM
2020-10-07 12:44 AM
HOW TO UNDERSTAND WHAT IS MISSING?? all folders in generated project are in place. Should be there some path included in environment variables??
Generate Assets
Failed
Failed
