2018-03-05 8:13 AM
In the emWin Graphic Library with Graphical User Interface User & Reference Guide Document: UM03001 Software version: V5.32 Document revision: 0 Date: October 6, 2015 delivered with the STemWin zip file named STemWin_Library_V1.2.0 nothing of the files mentioned is present in the zip file except for Prep.bat.
Neither do any of the mentioned folders exist in the zip file:
GUI\AntiAlias Antialiasing support *
GUI\ConvertMono Color conversion routines used for grayscale displays *GUI\ConvertColor Color conversion routines used for color displays *GUI\Core emWin core filesGUI\Font Font filesGUI\DisplayDriver Display driverGUI\MemDev Memory Device support *GUI\MT MultiTouch supportGUI\VNC VNC support *GUI\Widget Widget library *GUI\WM Window Manager *The directory tree mentioned in 2.1 Getting Started - Recommended project structure is non existant.
How to go about this? How to work with STemWin when the first chapter of the manual cannot be applied due to missing files and directories?
Thx.
#emwin #stemwin_library_v1.2.0.zip #stemwin_library_v1.2.0 #stemwin2018-03-05 8:59 AM
Hello
Toss.Piotr
,I think you are confusing between
STemWin and emWin
document usage:STemWin library based on SEGGERgraphic library emWin and we
recommend you to follow the
Application note for getting started with STemWin Library.Best Regards
Imen.
2018-03-06 7:08 AM
Hi Iman,
Thanks for your attention.I am not confused. The documentation, the emWin manual I am referring toabove, is taken from the STemWin zipfile itself. Hence I see this manual as part of the STemWin bundle. See attached STemWin zip file directory tree (attachment: Screenshot from 2018-03-06 15:05:png) where you can see the place I took the emWin manual from and of which you can see its contents of concern here (attachment: Screenshot from 2018-03-06 15:22:png). Hence ST will need to change the contents of the zip file and replace the emWin pdf document with the AN4323 pdf document and refer to the emWinmanual (1000+ pages) chaptersfor library syntax documentation.
Greets,
Ben
________________ Attachments : Screenshot from 2018-03-06 15:05:19.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxvB&d=%2Fa%2F0X0000000b2H%2FjmP_wSw83KO5SQGctMmqK_YyVN9xUP533pRecpZh1.Q&asPdf=falseScreenshot from 2018-03-06 15:22:42.png : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hxv6&d=%2Fa%2F0X0000000b2F%2FKd37OVcuK4Cip5AS6FyNIfdg.PWD7K6PgAsmm2kN0n0&asPdf=falseWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
