2021-01-27 8:41 AM
I am looking for the example from the picture below.
To save time, I want to reuse the graphics in my application (I guess those graphics are free of use).
Thanks!
2021-01-27 5:53 PM
Hello @Community member ,
I believe you can use them as they are. If you want to use it for a product you want to sell, I think it's ok too. I'm going to get confirmation.
You will find this example in TouchGFX Designer under the name TouchGFX Demo 2.
/Alexandre
2021-01-27 3:07 PM
The date and time setting widget/screen from the example boards is also something I'd like to use...
Keith
2021-01-27 5:53 PM
/Alexandre
2021-01-27 10:53 PM
Thanks @Alexandre RENOUX !
2021-01-27 10:56 PM
I confirm you can use the assets of the calendar screen you show in your post. Assets available directly for the style of widgets are completely free to use. And basically everything in the Designer is free to use. The only point when you need to be careful is when you try to sell your product using images from the available demos since we don't own all the assets in these demos.
But again for the screen you indicate everything is fine.
It's a good thing you asked ! =)
/Alexandre
2021-01-28 12:16 AM
Thanks, that will save us a lot of time.
I feel that I spend more time figuring out the graphics than actual coding!
