2023-03-21 5:20 AM
I'm trying to load some text data into a scroll list. Those texts are generated at runtime. I want to show them as list items. Also, the number of elements is not fixed. No sharply defined upper limit and lower limit for the number of elements.
2023-03-21 9:08 AM
Simply create array for this and use it in callback
item.setIco_1(touchgfx::Bitmap(UI_Menu_Icons_1B[itemIndex]));
item.setLabel_1(touchgfx::TypedText(UI_Menu_Items_1B[itemIndex]));ofcourse container need setter func
plus in setup or change func place
scrollList1.setNumberOfItems(sizeof(UI_Menu_Items_B));
2023-03-21 9:08 AM
2023-03-21 8:33 PM
Thank you for the anwser. But what is the data types of UI_Menu_Items_1B. Isn't it a array of resouser ids of texts , defined in TouhcGFX designer. So how could I change the text from code.
Thank you
2023-03-21 10:48 PM
I mean you can create item.setLabel in string variant and in container use wildcard...
2023-03-22 8:10 PM
Ahh okay. I'll try that. Thank you very much.
